Question about Sanyo CLT2054 20 in. EDTV-Ready LCD Television
I want to use this Sanyo as a monitor also... no s video on the computer
My son's computer does not have s video. Any ideas what to do.
  • Sanyo Master
  • 12,061 Answers
Get yourself a Video card with a TV output connector maybe AGP or IDE card, and then using the software that came with the card set it up for TV out... thats really the only way ya can get TV out to your other devices.
Posted on Jul 30, 2007
SOURCE:
Hi, When I connect my Samsung RF711 laptop to my Sanyo LCD-42XR9DA TV HDMI to HDMI, and source the HDMI 1 input and press OK I do not get any laptop display on the TV screen at all. I have spoken to both...
I suspect that the TV can't read the signal from the computer on the HDMI port. You would get a signal from a VGA connection. (Computers send a slightly different signal over HDMI than a DVD or blu-ray player.)
In general, when connecting a TV to a computer, turn off both devices before connecting the video cables. Then turn on the TV and set it to the source (with the no signal message). Then turn on the computer. Next set the computer to output the video on the external video port. (Depending on the laptop, you may need to enable the port in the BIOS. To access the BIOS, press Esc, F1, F2 or F10 repeatedly as you turn on the computer. The key depends on the brand of computer.) Next set the video output in the OS (depends on the OS). For Windows 7, right click on the desktop (anywhere there are no icons or running programs), select Graphics Properties and set the desired monitor choice (laptop monitor, external monitor, both or extended). Click Apply and then confirm this when the display changes. (At least this works for my HP laptop on the VGA port.; my desktop lets me change monitors under Screen Resolution.)
The manual for the TV is available here: http://www.sanyo.com.au/resources/manuals/tvs/lcd42xr9da_im.pdf .
I wish that I had better news for you.
Apr 22, 2011 | Televison & Video
My son has an LG W2234S monitor with his desktop computer. when you start up the computer the monitor just says power save mode and the screen then goes black. We have tried attaching the monitor to my...
If this monitor works with your lap top or the other PC (not your son's PC). Then your son PC video card may not be sending out the video signal so the monitor goes into power save mode.
Did you try another monitor with your son's PC yet?
Does the PC has plug in video card or it is integrated with the mother board, you can also try reseating the card and the RAM.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 29, 2010 | LG Computers & Internet
Can you hookup a computer to the sanyo ds32224
Yes, if you get the appropriate converter. You will need either a VGA to component video or VGA to composite video converter. Some of these are available here: http://www.svideo.com/pctocomponent.html . Since the computer VGA port provides an RGB signal and the component video is a YPbPr signal, the converter is essential.
However, the cost of the converter may not be worth using this method when replacement monitors are fairly cheap. (Christmas sales had 19" LCD monitors for under $100 with VGA input.)
I hope this helps.
Dec 27, 2010 | Sanyo DS32224 TV
I have Sanyo Model No. DS32224, is it possible to hook up the tv to be used as a monitor for my computer?
Yes. However, it may not be worthwhile.
Most likely, you need a VGA to composite or component video converter. See the following URL for some ideas: http://www.hdtvsupply.com/vgatococo1.html .
Some video graphics cards can output in a TV format. In that case, you just need the appropriate connector and to set the computer to do this. You need to check the specs of your card (or find one that fits your machine with the feature). These cards usually have an S-video output connection. Use this carefully - most computers output RGB and TVs do not read RGB signals.
I hope this helps.
Nov 29, 2010 | Sanyo Televison & Video
My sanyo vpc-cg20 monitor shows updide down how do i fix it
http://us.sanyo.com/Cameras-Camcorders-Previous-Models/VPC-E1-Waterproof-Digital-Video-and-6MP-Photos
The above is a description.
I checked the online FAQ's and support, but didn't find an upside down image on monitor problem.
So, I think your best bet for your waterproof camera is to have it serviced by Sanyo.com.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Jul 24, 2010 | Sanyo Xacti VPC-E1 Camcorder
Trying to hook my sanyo 32in up as a monitor for my computer running on windows xp when I hook it up it gets sound and acknowledges the cord is connected(the no signal sign goes away) but the screen just...
Your computer may be sending out a video signal that's too high of a resolution for your TV to display. Try reducing the resolution of the computer video signal.
May 13, 2009 | Sanyo DP32648 32 in. LCD TV
Turntable plate for Sanyo EMSL100N microwave
hI
IF YOU ARE IN THE uk CALL cHARLES hYDE and son
01759 303068
They have all the parts for Sanyo
Please leave feedback for me
Thanks
Rob
Feb 12, 2009 | Sanyo Microwave Ovens
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Windows multiplied
what your son did is change the video resolution on your video card. right click on a blank area of your desktop, this will bring up a popup menu, left click on the word "properties" in the menu. this will bring up your display settings window. click on the "settings" tab. this is where the video resolution and color parameters are set. under screen resolution, there is a slider. move the slider to the left until the resolution is either 800x600 or 1024x768, then click "apply". this will get you back to a screen resolution that most monitors are happy with. if you had a higher resolution setting before, follow the same process to increase the resolution. also there is an option that allows you to test the resolution setting, and if it doesn't work, returns windows to it's previous setting. i recommend you use that option.
Jun 28, 2006 | CTX Value VL 510 15" CRT Monitor
Sanyo CLT2054 20 in. EDTV-Ready LCD Television Logo
56 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
