Question about Acer AL2671W 26 in. LCD Television
ADVICE WHAT SHOULD I DO?
My tv is a acer LCD AL2671 26inch. I have problems turning on the tv and requires that I turn on and off the main switch under the panel several times before it will come up with a piture. I never have a problem turning it off Recently the picture has started shifting to the right of the screen. any thoughts before I call a tv repairman at least I will have some idea and what I'm talking about.
  • MICHAEL MADDEN Aug 01, 2007
    Thanks for the advice.Not sure what Im going to do yet great help.Thanks again.
  • NAEEM1234 Feb 20, 2008
    Problem Solver:
  • 7 Answers
Have the same problem...i will try the following: open case and check every capacitor on pcbs...the top of the capacitors have to be flat, than they are ok. - i think one ore more of these are the problem. if located it will be possible to change them for new ones...must have some expirience in desoldering/soldering. i will report my efforts soon...
english is not good, i am german....
Posted on Jan 30, 2008
  • Acer Master
  • 12,061 Answers
Well sounds like a Horizontal PSU problem... a component is or has gone faulty.. causing incorrect voltages to be generated.. thus the problem.. shouldn't be too hard to fix..It may be also an IC.. any TV repairman worth his salt should have no probs fixing it fairly easily.
Posted on Jul 30, 2007
SOURCE:
I have a AL2671w LCD Acer TV ON OFF switching
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Dec 05, 2009 | Acer Televison & Video
Tv will not switch on(not fuses)
Check out filter capacitros in the power supply section?
Oct 29, 2009 | Acer AT3205-DTV 32 in. HD-Ready LCD TV
Astar LTV-2701 27
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Jun 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice [email protected]
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Samsung 46" LCD TV stops responding
Ok, There are well three boards in this set that would influence such a behavior. The culprit is the Key Pad Board. It has what is called a leaky switch. This then locks up the Microprocessor. This will result in the set operating like a ghost has the remote.
best regards
CircuitCity
Dec 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Acer AL2671W 26 in. LCD Television Logo
276 people viewed this question
Top Acer Televison & Video Experts
Eric Rotmil
Eric Rotmil
Siul Oyaratgam
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
