Question about Gateway MX6450 Notebook
I would like to recover my Gateway MX6450 laptop but my cd-rom does not work. is there any way to recover the hard disk without the cd-rom being used?
  • 44 Answers
Two things come to mind. First off being borrowing an external DVD drive from someone, or purchasing one from your local electronics store.
The second one is using the recovery partition if it is still intact. I checked online and that model is supposed to have one, though I could be mistaken. When turning on the computer hold Alt and tap F11, that should start reinstalling the operating system for you.
Hope that helps :)
Posted on Apr 15, 2009
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
How can i reformat my acer aspire 4520 without cd rom?
Try this method it may work.
If you can boot up with the external USB hard drive on your Acer, then use a working computer and copy the Windows installation CD onto the external hard disk then connect the USB externak hard disk to the USB port on your Acer and boot up using the external hard drive.
Feb 18, 2012 | Acer Aspire 4520-5141 Notebook
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
Gateway mx6450 audio driver
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. It will be labelled Audio driver or Sound driver.
Hope this helps,
Jul 02, 2010 | Gateway MX6450 Notebook
I'm looking for recovery disks for a gateway MX6450 my hard drive crashed.
The system recovery process for your computer is stored on your hard drive. As long as you are trying to reload your hard drive, not replacing it then you can access and run the recovery application without going into windows.
The access the system recovery without going in to window:
Power your computer off.
Disconnect all external devices including printers and pc-cards (external mouse and keyboard can be attached)
Power you system on and watch very carefully for a message that says 'Press F11 to start system recovery'
Press F11 as soon as you see this message.
From her you can go through the recovery process.
Nov 14, 2009 | Gateway Computers & Internet
When I turn on my Gateway MX6450 the gateway logo will display then you see the windows logo then the screen goes blank. I need to recover the saved data if I can.
You could remove the hard drive and pickup an adapter online or from a computer retailer that will allow you to connect a 2.5" drive to a standard ide connector found in most "tower" computers. If this is a "SATA" drive it will not need this and can be connected as a 2nd drive with no problems.
Jun 24, 2009 | Gateway MX6450 Notebook
Hard drive from gateway solo pro 40 gig will it work in toshiba
I'm pretty sure it will. The only thing is that Gateways of that generationn used a custom connector which plugs onto the hard disks standard IDE / ATA connector.Just pull this extra connector off and you can use the disk in any machine.
Also ,Toshiba used similar adapters,so if Toshiba's using one on your model,then you'll need to palce the toshiba adapter onto the hard disk from your Gateway. You may also have to go into your BIOS ,and make sure the BIOS recognizes the disk if your BIOS isn't already set to "auto detect".
Mar 28, 2009 | Gateway Solo 9300 Series (5501056) Plug-In...
My gateway laptop will not display anything except the name GATEWAY. I was instructed to purchase an operating system cd, now that I have the cd to load it on the laptop I discovered it does not give me...
it shows the hard disk of your laptop is un-detectable. check the hard disk connector/power, if u can or consult a technician for the same. if it does. then put the system disk in to cd drive and boot from it.
Nov 28, 2008 | Gateway Computers & Internet
Gateway MX6450 Notebook Logo
154 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
