Hi i have a maytag front loading washing machine its about 4 years old haven't been able to find a model number either on the back or inside the door i get an number 5 error. the machine starts it filling of water than it comes up with the error Thanks rob
  • 15,935 Answers
I believe you are describing a tS code.
If it is tS showing it is an indication that the termistor is shorted. The thermistor is the temperature sensing device used on this dryer.
Before replacing the themistor check for a clogged lint screen or dirty vent pipe.
If these are clear and you are still getting the code the thermistor would need replaced, the resistance of the thermistor should be about 10K ohms at room temperature.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Maytag front load washer model #MAH4000AWW. Just happened! Water fills then nothing. Wife says it "seems" like it wants to do something but doesn't
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
I HAVE A WHIRLPOOL FRONT LOAD WASHER, MODEL WFS1072AW WHICH IS NOT YET 3 YEARS OLD. IT WASHES GREAT, BUT THE CABINET IS RUSTING OUT JUST ABOVE THE TOP OF THE DOOR. iS THIS AN ONGOING PROBLEM WITH THIS...
3 years old on a whirlpool and you already have rust do you live in a wet or damp area? usually you dont see rust until 4-5 years its due to the type of paint that they used in the factory not as good and the cheaper type than what they used to use be happy though that it is working properly most maytags around that same time frame end up having some serious run problems if you would like to replace the panel that is rusted message me back the model number and i can send you a schemtic diagram of how your machine goes together as well as provide the cheapest place to obtain your part by doing a comparison among a couple different suppliers if you have any further questions message me back with these as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
p.s on a maytag you start seeing some major problems around 2 years
Feb 08, 2011 | Washing Machines
Model - Maytag plus 2 speed. Will not spin everything else works. Machine ten years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Maytag Washing Machines
Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Grinding sound during spin cycle
Is this a front loading machine? Also whats the model number when you open the door? If this is a front loading machine and you haven't been using HE soap, it's almost certain it's the brearing.
May 25, 2009 | Washing Machines
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error number 5
if you look on the back of the machine you will find 3 screws securing the top of the machine. the top will then slide back and lift off. the tech sheet should be inside and will explain the fault code
Jan 31, 2009 | Washing Machines
Whirlpool AMW5125 washing machine approx 4 years old Spin action not working
your brushes are gone its a easy job and first thing is wright down the model number of the machine its normally on the door when you open it go to ebay on you should get some for £5 ounce you have took off the motor it that easy to put back on
Nov 11, 2007 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
