Question about IBM E74 17" CRT Monitor
Monitor setting menu keeps on coming again and again without manual adjustments anvar kodumunda
  • Anonymous Mar 10, 2009
    sceptre monitor won't keep settings
Pl replace front panel keys solve these problem
Posted on Mar 10, 2009
  • 83 Answers
I had a similar problem and it was when the drivers that had installed where incorrect, try unistalling and reinstalling the drivers, this worked for me. I had the problem on a 17" TFT monitor, the ATI drivers were set too high and caused a conflict
Posted on Jan 31, 2009
SOURCE:
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
My computer monitor keeps saying auto adjust how do i fix this
Usually if the auto adjust is flickering intermittently you can attempt to reset the internal values to the factory settings. To do so: press the menu key on your monitor then choose factory reset. Press the menu button again then select all settings.
Jun 19, 2010 | ASUS VW192S Monitor
E70fSB main menu keeps on prompting
your monitor low voltage regulator LM7805 inside needs replacement..electrical noise is entering the microcontroller of your monitor..bring the unit to the nearest monitor repair center..
May 10, 2010 | ViewSonic 17" CRT Monitor
I have an ACER X203H and cannot adjust the contrast or the brightness. I can bring up the MENU, however I cannot adjust because when I HIT ENTER the menu disappears.
Press the Menu key on the Monitor to bring up the dialog box press Menu again because it defaults to the Brightness Icon. You will see the lower half of the dialog box change color. Use the left or right arrow to move off of Acer eColor Management to the User setting. Then press Menu again to edit contrast or brightness. User the left and right arrows on the Monitor to move to the desired adjustment, press Menu to allow adjust then arrow left for less or arrow right for more.
You really just keep moving between the Menu and arrow til you get it right.. I definitely needed to turn down the brightness on my monitor.
May 04, 2010 | Acer X203H bd Monitor
Main menu inviting to take a tour on how to adjust the monitor keeps popping up uninvited.
Your screen settings are not optimized for that monitor, most Gateways (to h*&%) come with a drivers disks for the monitors put that in and run setup for the monitor.
May 02, 2009 | Computers & Internet
Want to unlock my monitor
This is the function that locks the OSD in order to keep the current states of
settings or prevent others from adjusting the current settings.
1. Lock : Hold down the menu button for more than five seconds to activate
the OSD adjustment lock function.
2. Unlock : Hold down the menu button for more than five seconds to
deactivate the OSD adjustment lock function.
Though the OSD adjustment lock function is activated, you can still
adjust the brightness and contrast, and adjust MagicBright ( )
using the Direct button.
Found at: http://www.retrevo.com/support/Samsung-713BM-PLUS-Monitors-manual/id/2994ag905/t/2/
Hope this helps and please remeber to give me a rating, thanks!
OpenSource13
Apr 06, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Monitor Menu Poping up again & again
1. First U can change Microswitches on front pannle (Menu,select,+,-)
2.check dry points in MICOM&EEPROM IC,HV IC and It's related.
3.check 5V supply and replace 5V Regulator.
Oct 05, 2008 | IBM E74 17" CRT Monitor
SCREEN MESSAGE - MODE NOT SUPPORTED
You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
IBM E74 17" CRT Monitor Logo
570 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
