Question about Ruud Heating & Cooling
Inducer motor starts and stopsin1 second before any call for ign
Model UGRA-07EM4ES
  • 96 Answers
Check your presure switch
Posted on Jan 31, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
What is the AFUE of my Rudd Achiever 90 Plus with model number UGRA-07EMAES
Per Rudd's website and also as the name implies, the min rating is 90. The 90+ can be as high as 93 but is stated as "plus" to cover the many possible installation scenarios which will impact overall efficiency of the unit.
Sep 11, 2014 | Heating & Cooling
Janitrol furnace, Model # GMT090-3, built in February of '02. The induced draft motor runs for a half second, then quits. Indicator light blinks rapidly and continuously, indicating 'incorrect twinning'...
I ran into a simalar problem and it was a short in the control wiring of the furnace. When there is a call for heat a relay closes to start the inducer the movement of air causes by the inducer closes the air pressure switch. This is where the problem starts.some where in the control wiring there is a dead short this causes the secondary (24volts ) to drop causing the inducer relay to open shutiing off the inducer which in turn opens the pressure switch removing the short and the cycle starts over again. The culprit in my case was the high limit switch which was shorting against the metal furnace housing. You can easily ccheck this by removing the two wires from the fan limit switch and powering up the unit to see if the inducer runs normally . If it does remove limit and replace if necessary.
hope this helps
Oct 10, 2013 | Goodman Heating & Cooling
Hello there, I have a Goodman GMH951155DXAC furnace that I got in 2007. I have the following problem for the last 4 years: When the thermostat calls for heat the induced draft motor comes on and 30-40...
With furnace OFF ,Disconnect the top of the hose that leads to the
Bottom of Daft inducer Box, Now blow into it water will come out
of the drain hoses "condensation " this will shut the unit down if not drained. There must be a Trap on the side of the Furnace with water in it , to have positive presure to suck out condensation. This will fix problem. some installers forget to install this Trap that comes with Unit.....!!!! A little item
that will shut the whole system DOWN. :o)
Jan 06, 2011 | Goodman Heating & Cooling
Trying to determine whether I have a bad Ign/Lockout or inducer relay board on Mod 58SXA080-GG. If I shut off heat at t-stat or unplug ign mod. for 10 min. It will usually intiate a heat cycle but I only...
The inducer blower will put a vacuum on your pressure switch which in turn will tell the board to apply power to the ignitor. If you have a vent blockage, dirty air filter, plugged condensate line or any blockage of either vent or air intake, the furnace will lock-out and flash an error code on the circuit board. If after inspecting all the above for debris and found nothing, you can quickly jump the pressure switch after the inducer starts to see if the ignitor glows. You could also have a bad ignitor. Yes the lock-out is normal. Looks like you discovered the cause on your own, order a new switch.
Feb 15, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Aug 10, 2009 | Heating & Cooling
Heater won't light
Not having a make or model number, I can only give you generic information. However if you add more info, others and myself can give you a better diagnosis.
In order for a furnace to start that has an inducer motor, the thermostat must call for heat. Then the circuit board will flash rapidly. There should be power from the board up to the inducer motor. If there is too much resistance, the blower motor or pressure switch(s) will shut down the unit. I would suggest that if you can spin the inducer motor by hand, check for resistance. It may be frozen up or there may be water in the housing not allowing the blower to turn. Check for a plugged water drain at the bottom of the blower housing and make sure it drains. If the inducer blower does not even try to start, you will need to check for voltage from the circuit board. Not knowing for what you have for a model, I am unable to tell you if you should be checking for AC or DC voltage.
Get back to us as soon as you can with more info.
Thank you for your patience.
Oct 18, 2007 | Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
