Question about Jet 3 Ultra Power Chair
Bolt broke that holds saftey seat latch on - where to get parts?
Part # dwr1000e131 bolts under the seat, bolt that holds this to safety latch and trapeze bar snapped, partial bolt is still inside this piece. where can I get these parts? Cannot even find a parts manual.
  • 34 Answers
One of the best places my be a Automovtive supply stores , you may also try a Home improvement store, they tend to carry "odd" Bolts, to remove the broken bolt you may have to drill it out with a special drill tip also avaliable at most of the Home Improvent stores,, make sure you take your broken piece with you if you still have it so you can get a perfect match.
Posted on Feb 17, 2009
Sorry the mower is Poulan pro 625 ex the bolt broke that holds the the blade on need to buy new one what size or type do I need . Please and thank you
If the bolt broke, you need to remove the threaded part of the bolt that is still in the shaft... once you get the broken part of the bolt, out.....it (the threaded part) will tell you what size/thread pitch you need... just take it with you to the mower store or a industrial supply store..
Fastenal Industrial Supplies OEM Fasteners Safety Products More
Grainger Industrial Supply MRO Products Equipment Tools
Jul 14, 2017 | Poulan Garden
I need new seat belt latches. Dog chewed plastic off; belts won't lock.
Junk yard. Google "junk yard" and your location and you should get some hits. Or I like car-part.com. Once you get them, you should be able to access the bolt that holds them in place by moving the seat all the way forward (assuming that we are talking about front seats). There should be a plastic cover that "pops" off with a little influence. Remove bolt, install new/used part.
Apr 20, 2013 | 1999 Honda Accord
Third row seat latchs are broken and seats stuck in upright possition
There is a plug (cap) that goes into the pivot point of the release handle for the third row seats. If that plug is missing, you can stick a penny in there temporarily to enable the release and fold the seats down. The replacement part is called a "release handle plug" -- I found it at moparpartsovestock.com, part number 1ED82BD1AA for under $4.
Jul 01, 2012 | 2006 Jeep Commander
Rear seat removal, fx yamaha jet ski, latch will not release the seat
As bad as this sounds its the only way. Grab yourself a 2x4 and a nice size prybar.
Lay 2x4 across the back grab handle as to not damage it then put prybar directly under seat latch and pop it up.
Oct 29, 2011 | Yamaha 12V Air Pump
The drivers seat belt will not latch, and the release button seems broke. What can I do?
You can go to the junk yard, or the dealer and get a replacement latch. The latch should be attached either to another piece of seat belt, or its a cord that is bolted to either the seat or the floor. Should be torx or star bit that removes it, its pretty simple, but worst case scenario you may have to remove the seat to access it. Seats are usually only 4 bolts and a wiring harness that you can unplug. I don't take chances with seat belts, so you may want to ask the dealer. Parts store may sell them, but I'm not sure.
Mar 09, 2011 | GMC Yukon XL Cars & Trucks
Ford Escape middle rear seat belt stuck
Hey everyone--after searching in vain for an entire 10 days, and absolutely REFUSING to pay Ford's $100 diagnosis fee, and their $300 replacement suggestion ($400??), I decided to figure this out myself. And I did. Do the following to let loose the tension that has kept your seat stuck in the down position (though my truck is a 2008 Ford Escape, I have a strong feeling this is the case with any vehicle):
1. Remove the seat bottoms (which are folded forward and upward against the back of the front seats). To do this, find the bars that are bracketed into the floor. There may or may not be a little yellow lever on one of the two brackets. If so, flip it and slide the bar out. If it stops, pull the other side out. Doing this should allow you to completely remove the seat from the car. Repeat with other side.
Now you should have plenty of room to work. Move front seats forward, and you've got even more.
2. Remove your back seats entirely. (Sorry- it's a must.) For many, you will require either one or both of these:
One Torx T-50 socket to remove T-50 bolt (which bolts seat belt latches to the floor)
One Torx T-55 (which bolts the folding seat into the bracket that bolts seats to the floor).
One socket extension (tip: the extension gives you much more torque, and its easier to remove bolts) and
One a 5/8" socket. (See continuation after following tip.)
TIP: if you have a 40/60 split, you have to remove the 40 first! This will allow you room to move around the 60 seat and its stuck belt.
Continued:
Remove bolts that bolt bracket to car floor (this is the 40 seat). I believe there's two: 1 directly below the seat, and 1 that also bolts the 60 seat (you'll be using the 5/8" here)-- Don't hold me to it, though, as I've seen some different stuff. Pull seat out of the way to avoid potential damage. NOTE: THOSE BRACKETS ARE SHARP. WATCH THE LEATHER/SEAT MATERIAL-- AND YOUR HANDS.)
2. Remove bolts on the 60. Though the top part of your seat is down, you should be able to the bolt that keeps the bracket to the floor beneath where the seat cushion would be (and where the upper part of the seat is laying flat). A ratchet would probably be best for this since you can keep the socket in place and wind the thing completely out. I should say here that my seat couldn't have been tighter to the floor. If I got mine out, I'm sure you can, too.
Now here come the tricky, but verrrrry easy parts. They are vital.
1. Now that the brackets are off of the floor, the 60 seat should now be free-floating in your hands, but tethered by the T50 bolt that is keeping the seatbelt buckle to the floor. Remove it. Now you should be able to remove the seat altogether. I had to bring mine inside where it wasn't 15 degrees in my garage, but I believe you'll do these parts in the next five minutes. Do this next:
2. TIP the 60 SEAT UPRIGHT (just like it would if things were back to the normal operational mode). This is VITAL. If you cannot fix it with two or three tugs from here (don't waste more time than this-- the final part is coming), then do this next:
3. Find the latch on the back of the seat that locks onto the latch of the car. Using two gloved fingers (or tools), press the latch inward until it's in the LOCKED position (fooling it into thinking you've put it up and latched into into the truck bracket).
This should have also reset the button or lever that you used to unlock the seat in the first place. Now give your belt a tug. It should come loose like normal.
IMPORTANT NOTE: seatbelt tensioners rely on gravity (thing momentum during a crash) that locks the belt. If the seat is not sitting UPRIGHT (like in normal use mode), that mechanism is going to obey gravity if it is tilted backward or forward (which is why the seat got in the downward position to begin with) and lock.
That's it. Bolt the seats back in, and go buy yourself $400 worth of rewards.
Oct 31, 2010 | 2008 Ford Escape
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
Seat bolt broke
drill the original bolt out and place another bolt from underneath, screw on a nut from the top
May 16, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
Disconnected hood latch
in the front in the back of the front grill look near the top middle the latch is there if our lucky you should see the black cable that the hood pull on it it should realese itself if not you have to go with a screwdriver and wiggle it hope it help fixya our post thank you pierre
Jul 15, 2008 | 1994 Chevrolet Caprice Classic
Jet 3 Ultra Power Chair Logo
178 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
