Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
There is no water coming out of our fridge's water dispenser
We already changed the water filter thinking that is was just old and clogged but that wasn't it, we have water coming all the way to the freezer door (we checked the hose on the bottom of the freezer door going into the freezer door) but it stops in the freezer door somewhere. What can we do??
  • 150 Answers
Sounds like your line has ice in it.Try thawing it out by turning it off and leave doors open,put pans of hot water in to speed it up.
Hope this helped.Let me know by rating me
For more help go to live chat.
len west
Posted on Jan 31, 2009
Water dispenser beep-beep
I am wondering about the hose you shoved in and the leak stopped. Is the hose you pushed in buckled where it hooks on or is there a buckled spot where the water comes out of the fridge. Just a guess.
Mar 03, 2017 | Hotpoint HSS25GFP Side by Side...
Water dispenser and icemaker not getting water on a maytag fridge
pull line off of the back of fridge to see if water comes out if not its where ever you have that line taped into yuur water supply for the fridge had the same problem hard water clogged up the tee off take it off poke some thing in the little hole make sure you have the water shut off to the water supply when was the last time you changed the filter in you fridge it could be tht too
Nov 12, 2011 | Refrigerators
Kitchen Aid Fridge KSRIZ6DSALYO Water no longer dispensing from door. Can a filter get too old and get clogged or should Iook at something else?
the filter can become clogged and restrict the water flow to the water dispenser and icemaker (i.e. water dispenses slow or small/hollow ice cubes). if the filter doesn't fix it then you either have a water supply problem or a faulty water valve. take the filter out and see if the water pressure increases out of the dispenser. if it does, you know its the filter. hope this helps.
Oct 22, 2009 | KitchenAid Refrigerators
The water will not come out of the door. The ice will work though.
My GE Profile has a system water filter. The manual said that if the filter clogs--it will not allow water to pass thru--any ice already made will still dispense but no new ice will be made. If you have a filter and it is over 9-10 months old, it could be clogged.
Jul 04, 2009 | GE Profile PSS26NGS Side by Side...
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My side by side whrilpool refreg
First of all, is there a reset button that needs to be pushed after changing filter? Mine has one. Check around the sides and top inside the fridge for a little button and push it in.
Is the water turned on going to the fridge?
If it was working before you changed filter, maybe the water line got kinked somewhere and no water can come through.
Also, if filter isn't reinstalled correctly, no water can come through it. Make sure the filter is not upside down and that the holder is screwed in all the way.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Conquest water filter in my whirpool side by side
yes it is. as long as there is still water coming out from the dispenser.
the red light only indicates that it is about time to replace the filter. could be 6 months old. this is controlled by time, so check your water pressure at the dispenser, if it is still strong, then you could still use it .
depending on your condition, some filters would be clogged already even if the light is still green and there is no more water coming out of your dispenser.
normal time to replace the filter is six months.
tnx 4 using fixya,
Oct 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water does not come out of the refrigerator door, but the ice works
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, When the water dispenser is pushed you can hear it try to work (a humming or pumping sound) but nothing comes out.
Below is a list of reasons that the water may not be working that are easily checked and remedyed by you! Is there a water shut off on your fridge?If so the dispensor will still make noise as if it is trying, even if it is locked!!!!!!!!!!!!!!!!!!!!!!!
1. When did you change the internal water filter last?
You can remove the water filter and still use the water dispenser to check if the filter may be the problem!If nothing changes reinsert the water filter.
2.Flushing the water system after replacing filter
Use a sturdy container to depress the water dispenser bar until
the water begins to flow. Flush the water system by dispensing
and discarding 2 to 3 gal. (8 to 12 L) of water. Cleaning the
system will take approximately 6 to 7 minutes and will help clear
air from the line. Additional flushing may be required in some
NOTE: As air is cleared from the system, water may spurt out of
the dispenser.
3.***Read this:
The dispenser lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
accidental dispensing by small children and pets. To turn off the
dispenser, press the LOCK button. The indicator will appear
above the LOCK button and the ice and water dispensers will not
work. To unlock the dispenser, press the UNLOCK button until
the indicator appears. Then continue to dispense ice or water as
NOTE:********** The lock feature does not shut off power to the product,
to the ice maker, or to the dispenser light. It simply deactivates
the dispenser levers.
4.The water dispenser will not operate properly
 Has the water system not filled? The water system needs
to be filled the first time it is used. Use a sturdy container to
depress the water dispenser bar until the water begins to
flow. Flush the water system by dispensing and discarding
2 to 3 gal. (8 to 12 L) of water. Cleaning the system will take
approximately 6 to 7 minutes and will help clear air from the
line. Additional flushing may be required in some households.
See the “Water and Ice Dispensers” section.
 Is the water shutoff valve not turned on or the water line
connected at the source? Make sure the water shutoff valve
is turned on and the water source is connected to the
refrigerator. See the “Water Supply Connection” section.
 Is the water shutoff valve clogged or incorrectly installed?
See the “Water Supply Connection” section. If clogging or
installation is not a problem, call for service or contact a
 Is there a kink in the home water source line? If you find or
suspect a kink in the water line, call for service.
 Is there a water filter installed on the refrigerator? The
filter may be clogged or incorrectly installed. First, check the
filter installation instructions to ensure that the filter was
installed correctly and is not clogged. If installation or
clogging is not a problem, call for service.
Please remember to leave a rating before you go!
Thank you,
Sep 29, 2008 | Whirlpool GD2SHGX Refrigerator
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
219 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
