Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote don't work at normal distances anymore (not the battery)
I have a Craftsman 1/2 (about 2 years old). The garage opener no longer recognizes the remote control units if you are using them at a normal standard distances (say...out in the driveway). This had never been a problem before, as I could open the door from a block away. If I stand directly under the motor housing in the garage w/ the remote, the motor will activate. I have already replaced the batteries in the remotes. The door does not "do better" with one remote verses the other. In addition, the external Security Keyless entry pad sometimes works and sometimes doesn't as well. The Premium Control Console (hard wired) always works when I push the button. I have "straightened" the antenna wire coming out of the motor housing. The motor housing LED is not lighting up or blinking to indicate any diagnostic info. while out in the driveway, I can sometimes get the door to open if I stand there long enough and keep pressing the remote button.
Any help would be appreciated since I don't want to buy a new logic board or oveall unit. Of course the warranty is out after a year and a half.
  • 22 more comments
  • Anonymous Mar 11, 2014
    error e000010 in canon ir 7105
    windows xp will not start properly and keeps cycling to start windows normally window.
    There is no power to the external ice & water dispenser. The light doesn't work, and the water and ice will not dispense. The ice maker is working fine. Thank you.
    trying to find starter relay on 2004 corvette
    Cancel my Facebook Account
    Engine not running right
    06 range rover supercharged need help no 5th or 6th gears
    I need to serial number for internet download manager
    hyundai elantra suspension diagram
    1976 chevy laguna vin number locations
    My engine is constantly overheating when in idle! The oil light is always dinging and if I dont keep the oil over filled then it dont even want to start up and I cant park it downhill at all! Sometime it seems like it has trouble shifting!
    HDMI sound in advance of video
    2010 mazda cx7 how do I get the bulbs out
    hard to open door
    I need to recover deleted files. I don't know how they were deleted but I need them back they are studio sessions of my clients. HELP!!!
    remove washer resevoir pump 2006 pontiac torrent
    check engine light comes on then resets after a while
    does a2007 silverado have a plug for installing a brake controller
    we jumped it a month ago and got it going so i went and bought a neww battery and it truns over it just wont fire
  • Anonymous Mar 12, 2014
    bike will ideal for ever with no problem. but when given some throttle it wants to cut out
    how to remove the rear bumper on a 2011 Cadillac srx
    No matter how close i start or far from my house the distance is about 30-40 feet and i can without a problem lock and unlock my car doors but I am un able to start it no matter the wether conditions.
    how to remove 5.7 vortec engine out of 99 chevy tahoe
    car will go in gears but the indicator shows in reverse when it is park
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, based on your description, most of the usual suspects have been eliminated.
  • remote batteries - replaced;
  • remote itself - tried several;
  • Security Keyless Entry Pad - similar issue;
  • Premium Control Console - works;
  • antenna - "straightened"
  • diagnostic - no errors.
Keeping the in mind that the simplified operation of the garage door opener is:
  • battery/remote > antenna >>>> antenna > receiver > logic board > motor actuator > motor and that
  • under motor housing, remote will work;
the possibilities left are:
  • remote's internal antenna (very unlikely);
  • receiver antenna (likely);
  • receiver (most likely);
  • logic board (a possibility).
Things you can try:
  • replace/extend antenna;
  • check/re-solder antenna connection to receiver board;
  • check receiver board, specifically, the filter capacitor and/or if it is getting the correct DCV from the power supply unit.
Alternately (though a remote possibility), it may be spurious radiation/RFI from other wireless equipment within the immediate vicinity of the receiver such as wireless phone, Wireless Routers, CB/HAM/Amateur radio equipment, wireless surveillance equipment. As stated, a remote possibility only. To my knowledge, most versions/models similar to yours operates on 315~390 MHz or there abouts.
Good luck and thank you for using FixYa.
Posted on Jan 31, 2009
  • 81 Answers
Hello
verifier your craftsman if the iron rust
you can use one oil ....
    Scholar:
  • 51 Answers
One thing you could do, (as a Diagnostic approach) is:
  • Make the antennae wire longer. Do so by stripping the end off of the wire and twisting an extension on the end (speaker wire works well).
Try this, and see if the range improves a little. If it doesn't, maybe replacing the Antenna would solve the problem.
Another thing to do is replace the batteries in the transmitter (on the unit) [*if you haven't already done so..)
I wish you luck.
  • xiller8er
    xiller8er Jan 31, 2009
    Also, you could try the unplug, replug, reset trick..
    • One more Diagnostics test you could do is: With a helper;
    • Have someone push the remote from out in the driveway while you watch the LED by the learn button.
    • If it flashes when they push the remote, the logic board is probably bad.
Remote no longer works for craftsman opener model #139.53674SRT1 and don't have manual to figure out how to reprogram it.
First make sure the battery is good. Locate the smart/learn button on the rear of the motor unit. Press and hold the button on the remote and then press and immediately release the smart/learn button. If the remote still works it will be programmed.
Aug 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Remote transmitter stopped working, changed battery, reprogrammed opener and it works but now only at a very short distance - about 1 -2 feet. Is this a transmitter issue or the opener?
There is no way to tell if you only have the one transmitter. If you have another remote or a wireless keypad that is working normally then it is that remote.
Jul 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP Garage Door opener problem
The remote and the keypad work through a signal sent to the receiver while the wall console, as you said it's wired directly to the opener, so it's likely that the receiver is shot. I'd try reprogramming the remote to just rule out the chance that all code wasn't erased first. (Press the learn button on the back of the operator head, stand back 5 feet and within 30 seconds slowly press the remote button a few times to see if it operates the opener). If this doesn't work, you can install an external LiftMaster universal receiver with the correct frequency and you should be good.
If there's a purple antenna hanging off the head, this is a 315 freq, use a 356LM, if black it's a 390 freq, use a 635LM receiver.
Then you'll have to reprogram your remote and keypad to the receiver.
Since there's also the issue with the light, there's also a possibility the circuit board got fried. Did you have any storms lately?
Aug 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only 1 remote will work at a time
One of your remotes has reverted to an earlier technology and they will no longer work with each other. You need to purchase a new remote making sure you get the same model number. Then you will find you can program 2 that will work with each other and 1 that will not. Remove the battery from the bad remote and toss it so that it doesn't cause problems down the road.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cant get 2 remotes for garage door openers working at same time
You have a remote that has reverted to an earlier technology. The only way out of this is to purchase the same exact model number called for by your opener and go through the programming. You will find the new one will work with one of the old ones. Remove the battery from the one that isn't and drop it in the garbage.
May 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work outside of garage it works up close
doesnt work at all or only close. if not at all, recode remote. if short distance, try reaiming antenna wire.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
128 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
