Question about Kenmore 64732 Electric Dryer
I need to put the belt of my dryer ithe correct place
My dryer had something disconnected in it so I opened the dryer up and found that the belt was the one disconnected. How do i out it back in?
Take out all the screws on the out side of back panel pull the drum back place belt over the front of drum and slide on release spring place belt behind pulley and replace spring
Posted on Jan 31, 2009
My dryer squells through the entire cycle.
You will need to replace the dryer belt. To do this follow the instructions below
  • Disconnect the power for your dryer before beginning any work. It can be disconnected from the wall outlet.
  • 2
    Open the top of your dryer cabinet and tilt it backward.
  • 3
    Use a Phillips head screwdriver remove the top two screws. Put the screws in a safe place.
  • 4
    Tilt the front forward and roll the belt around the drum.
  • 5
    Remove the old belt by lifting the drum slightly in order to give way to the front supports. You may have to open the dryer door to help the belt fall to the bottom of the basket.
  • 6
    Position the new belt by aligning it in the correct position before beginning to thread it through the motor pulley and idler. It will take someone with strong fingers and skinny arms to be able to get past the drum in the front. The dryer belt in a General Electric dryer has to be threaded looking in from the back.
  • 7
    Reassemble your dryer by replacing the screws in the top of your dryer.
  • 8
    Close the top and slide the dryer back against the wall.
  • 9
    Reconnect the power to your dryer by plugging the cord back into the wall outlet.
  • May 02, 2011 | GE Dryers
    Need instruction for replacing a drive belt on a electric dryer Model No. DE482 Serial # 07
    Best to move the dryer to a big room (hopefully cardboard if carpet is not available) as you will need to move around and move IT around some. Once you've got a nice clearance to work in, place the dryer onto its FACE-to clarify, the side that has the door that you open to access clothing articles should be on the ground. You will need to remove the back panel. This is the only way that you can replace the belt as there is a belt tensioner you will need to access also. The belt is long but not very wide or thick. There will only be one way you can fit the belt in place, have it be nice and tight, without having any slack. You might need a friend to hold the belt in place around the large DRUM (the area clothes are placed for drying) while you are routing the belt into place. There are only 3 places that the belt needs to contact: The DRUM, the motor shaft (this is what causes the belt to turn the drum), and the belt tensioner. The drum (with a friend holding the belt in place) and the motor shaft should be a snap, it might take a couple of tries to figure out how to correctly route the belt through the tensioner. When you have routed the belt correctly, the belt will be snug, the tensioner should flex (a little), and should be in the same spot the old one was. There is NO WAY you can install it backwards. Before putting the back panel on, turn the drum by hand a little to make sure you haven't missed or forgotten anything. Not a big job, not time consuming, just be careful you don't take any shortcuts and it should turn out great!
    If you need more help, I found parts breakdown prints here:
    http://www.appliance-parts-warehouse.com/maytag-parts/model_view_cats.cfm?model=DE482
    Hope this helps!
    Nov 08, 2009 | Dryers
    How to reinstall Idler Pulley and belt for kenmore Dryer Model 110.66112501
    First, assuming you have the drum out, there are two slots on the bottom plate of the dryer, hook the end of the idler pulley into the left slot with the angle as you look at it up and to the left. as you set the pulley in place the second slot will match the prongs of the idler pulley. With the idler in place, now put your belt around the drum (you should see a polished spot where the original belt rode and wore off the paint). Then use the belt to help guide the drum install. Set the drum on the rollers in back, keeping the drum level to the dryer. It helps if the whole dryer is tipped back against a wall at about a 45 degree angle to get the drum in place, but that makes your aligning the belt a pain at the same time. I suggest have the dryer at an angle to put the drum in then place it level to align the belt.
    You'll need to use both hands to get the belt in place. First thread the belt under the idler pulley wheel in the opening under it. Next you'll need to push the idler wheel as far up and to the right as you can to get the tension all the way off as you hook the belt around the motor. Once on the motor, slowly let the idler down into place.
    If everything is aligned correctly it will work just fine. Just make sure when you put the bulkhead in again that the drum rides on top of the slider pads and that the drum rotates freely with only the motor tension on it. 839edf2.jpge839dbf.jpg
    Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
    How do you swap the belt on the AWZ7303?
    Hello. I am trying to get the inforamtion for you that you are needing. To start with, your model number does not match a Whirplool dryer. If you open the dryer door, there is a serial plate on the frame of the dryer with your Model Number. Once you have gotten, this, I can instruct you on which belt fits this model. When you buy your parts from us here at Accurate Appliance, we will ship your belt to you and provide an instruction sheet on exactly how to replace the belt. The instruction sheet has a diagram of where to place the belt. 9728599092 is our number. Please call me with your information and I can ship to you today. Hope this helps!
    Aug 14, 2009 | Whirlpool Dryers
    Front loader Electric Dryer the belt
    It's not that hard, but it can be a little tricky. First UNPLUG the dryer or turn off the gas to it, whichever is applicable.
    Then, assuming you have the new belt, you will open the lint filter door. There will be two screw heads visible. Remove them. Place a knee in the center of the dryer just below the top. Place your hands at the front corners and **** hard while pressing with your knee and lift up on the top of the dryer. Once you do this, tilt the dryer top back until it rests on the wall behind the dryer.
    Next remove the two bolts at the top front corners. Disconnect the wiring harness connector for the door switch and lift the front panel of the door up and away from the rest of the dryer. You will notice the drum rides on the front panel and will fall down.
    Take out the old belt. Loop the new belt around the drum in the same approximate position that the old belt was riding. Take a small loop of belt and push it through the tensioner while lifting the tensioner to relieve tension off the belt. Then loop that end around the motor pulley.
    To re-assemble the dryer, reverse the directions for taking it apart. Remember to hook up the wiring harness. You will have to lift the drum into place to make sure the felt on the front and rear ride correctly on the guides.
    Jun 24, 2009 | Dryers
    Drum belt tension
    I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
    Problem solved.
    May 11, 2009 | Maytag Dryers
    Can't get replacement parts back on Kenmore 60 series dryer.
    The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
    Dec 24, 2008 | Kenmore 62602 Electric Dryer
    Kenmore 90 seies belt replacement
    you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
    Apr 05, 2008 | Kenmore 65924 Electric Dryer
    Kenmore 64732 Electric Dryer Logo
    70 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Richard Roth
    Richard Roth
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
