Question about Philips Magnavox 42MF521D/37 Television
Vertical line on screen
My magnavox 42" lcd tv [only 30 days old]now has a line vertical like a lighting bolt.It is not a soild line and can only be seen with certain backgound colors like blue sky or light colors.Any body no what this might be everything else is great picture. thank you
    Sniper:
  • 60 Answers
Hi, This is a problem that's far too common among flat-panel and projection LCD TV's?and it's generally known as "vertical banding." If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. These faint vertical bars (often most apparent when the screen is totally dark or displaying a solid background, like the sky) are defects that occur during the manufacturing process, and while the worst offenders are typically screened out, many more make it to store shelves. Since you've pinpointed the banding and it's driving you nuts,also its under warranty, call the manufacturer and demand a replacement; in most cases, they'll capitulate and send you a new set, although you'll probably have to go to the trouble of packing and shipping back your defective TV (make sure the manufacturer covers your shipping costs). Regards sreejith
Posted on Jul 30, 2007
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
LG LCD TV 42LK450 - Sound but screen is black..
Sorry but you have a bad panel. Repair cost is prohibitive. The T-con was a good choice, but is the last step to the panel.
Feb 13, 2014 | LG 42 42LK450 42 LCD TV
The SONY LCD TV is 2 1/2 Years old about 6 months ago I noticed a very light pink 3in vertical line, now after the tv is on for about 30 to 45 min the line is black. does any one have a clue how to fix...
The line or dots on an LCD screen are because of dead pixels and tolerable upto a certain limit as per policy of the manufacturer. But line is not permissible and should be changed in the warranty support. The isssue you are reporting is the vertical line and the the film is to be changed. So if the set is not in warranty it might be a big expense as there is no way to fix it at home.
Thanks
Oct 07, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Screen Goes Green, with Lines and jumps. 42LG30 1080p TV.
The TV is under a LG factory 1 year warranty.
Unless you bought a refurbished unit which has a 30 day warranty.
Contact LG @ 1 800 243-0000 for warranty repairs.
Be sure to have the...
Date of purchase
Model#
Serial#
And Product code.
The information is on the back of the TV or on a small white tag
on the side of the TV.
Jan 09, 2010 | LG 42LG30 42 in. LCD HDTV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Lines distorting the picture appearing on the screen
It's the Electrolyte Capacitor ( Elco )on the Vertical board that already damaged, try replace it with new ones.
Oct 18, 2009 | Dell W3000 30 in. HD-Ready LCD Television
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
On an LCD TV? Sounds like you've got a bad TCon board.
Jan 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Oct 10, 2008 | Televison & Video
Philips Magnavox 42MF521D/37 Television Logo
415 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
