Question about Motorola Mobility MOTORIZR Z6tv Cellular Phone
Buttons Are Falling Off!!!
Both the center button and the arrow ring around it have fallen off. After cleaning the excess glue residue off I would like to now reattatch them, but I don't know what glue to use.
  • 1 more comment
  • scott003 Feb 08, 2009
    The glue gets soft when phone is in my pants pocket. I lost the center "okay" button months ago, but the phone still worked. Now the rocker ring is coming loose and that little plastic strip that helped open the slider came unglued and fell off as well. I hope Verizon will replace it...
  • Anonymous Apr 22, 2009
    I am now on my fourth Z6tv. There are so many problems with this phone. On 3 of the phones the plastic bar which helps sliding the phone has fallen off. The phone is still functional, but that little bar is very convienent. Does any type of glue fix this problem without leaving marks all over the phone. I still don't mind to use it with the bar, but in a couple of months I expect this phone to utterly fail like the other ones. Is anybody else having this trouble as well?
  • doumaec May 13, 2009
    my center and directional buttons have fallen off as well!
I had the same problem, except 2 buttons (middle and the surrounding one) fell off, then the jell stuff underneath ripped and came off too. i called the company and since it's still under manufactureres warranty they can send me a 'like new' referb free... i tried to get them to just send me the button replacement but apparently they can't do that.
Posted on Feb 28, 2009
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
I have an Invacare M71 Pronto and the I am having a hard time with the on off button on the joystick control. I had it cleaned and the two gold covered pads directly under the on seem to be dark. Where...
No need to replace the circuit board just take a pencil eraser and rub the gold contacts to clean them making sure that you clean the residue after cleaning. the faceplate buttons have a metallic coating under the button and over time will wear off. You can glue a small piece of foil to the bottom off the buttons and the switches will work fine Since you have already purchased a new faceplate you can install it or you can glue foil to the bottom of the on/off button of the old faceplate and keep the new for later if you need it. Hope this helps you
Mar 18, 2011 | Invacare Supply Group 10" x 3" Foam Filled...
My hp color laserjet 2320 printer when i receive fax 6 times ringing i want make it 1ring
Set the number of rings-to-answer To set or change the number of rings-to-answer, use the following steps:
  1. On the control panel, press Setup .
  2. Use the arrow buttons to select Fax setup , and then press OK .
  3. Use the arrow buttons to select Basic setup , and then press OK .
  4. Use the arrow buttons to select Rings to answer , and then press OK .
  5. Use the up and down arrows to enter the number of rings-to-answer (1 or 2), then press OK .
All Done! Good luck!
Nov 29, 2010 | Home
How to change chinese language apple mac to english
  • Press the "Menu" button to display the main settings menu on the LCD.
  • Use the left and right arrow buttons to navigate to Setup Menu 1, which has an icon of a wrench and a numerical "1" on the tab. Press the center of the controller
  • Use the up and down arrow buttons to highlight "Language" and press the right arrow button to display the options.
  • Use the up and down arrow buttons to highlight your preferred language, then press in the center of arrow buttons to apply the change
  • Nov 23, 2010 | Apple MacBook Mac Notebook
    Replace power window switch on a 1998 ford mustang
    are the buttons not working? test fuses and relays. are the buttons falling inside the door? gorilla glue it back in place. the curvy panel on the door with the handle pops off. there is a small groove near the top to help pry it off..
    Aug 11, 2010 | 1998 Ford Mustang
    THEFAX IS PICKING UP THE LINE AND NOT GIVING ME THE OPPORTUNITY TO PICK UP THE PHONE TO TALK
    On the operation panel, press the following buttons to select DRPD.
    1. Press <Fax>.
    2. Press <Menu>.
    3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
    4. Press the right or left arrow button to select [DRPD], then press <OK>.
    5. Press <Stop/Reset> repeatedly to return to fax standby mode.
    On the operation panel, press the following buttons to select the correct ring pattern.
    1. Press <Fax>.
    2. Press <Menu>.
    3. Press the right or left arrow button to select [RX SETTINGS], then press <OK>.
    4. Press the right or left arrow button to select [DRPD:FAX RNG PAT], then press <OK>.
    5. Select the proper ring pattern: NORMAL RING / DOUBLE RING / SHORT-SHORT-LONG / SHORT-LONG-SHORT / OTHER RING TYPE . Press <OK>.
    6. Press <Stop/Reset> to return to fax standby mode.
    Feb 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    Timex Expedition Indiglo light no longer works?
    Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
    Jun 22, 2008 | Timex Expedition 40141 Wristwatch
    Shampooer
    If it is falling off (and lodging itself into the hose) I would suggest gluing it in place on the tank...a super glue should keep it in place and there is no reason to remove it. If its glued to the tank there is less chance of it being damaged.
    Feb 18, 2008 | Kirby Ultimate G Bagged Upright Vacuum
    Samsung- SGH-D820 key problem
    Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
    You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
    But if you hawe waranty, use ti!!!
    Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
    Motorola Mobility MOTORIZR Z6tv Cellular Phone Logo
    104 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    D. E. Hev
    Lawrence Oravetz
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
