I have a Canon PIXMA iP3000 printer, I have cleaned the color heads several times, but I still get lines across the paper when I print
  • Anonymous Feb 11, 2009
    orange light flashing then cut off print
  • 315 Answers
It sounds like you need to run printhead alignment.
Though I cant find a manual to tell you how to do it sorry.
Mike
Posted on Jan 31, 2009
Canon PIXMA iP3000. I have completed a nozzle check, but have odd results... BLACK-Perfect CYAN-4 EQUALLY SPACED WHITE LINES...NO DROP OUTS PALE CYAN-PERFECT MAGENTA- 4 EQUALLY SPACED WHITE LINES...NO DROP...
Inkjet printers do not like being left unused for long periods.
Some of the color print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked print nozzles.
If none of this works then the print head needs to be replaced.
A new cartridge will not solve this problem.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 17, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet...
The print head may be failing, you would have to send it in for service for a checkup.
Noting wrong with your cartridges its the unit that is controlling them. They 'fail' eventually and cause this.
Got warranty? maybe they will fix it for you free.
Check with canon or your dealer.
Thanks,
Ekse
Jul 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip3000 Color problem
This is a frequent complaint and only high-end equipment provides the necessary tools to correct the differences between display and printed output.
If the output is otherwise pristine, you can't do much about it, although if there are clear defects (streaks, etc), you might try running the provided cleaning routine on the printhead.
If you play with the brightness and contrast controls of your monitor, you will see that these can influence the color and saturation of what you see and the printer is not capable of seeing the same thing as you.
Aug 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Won't print black
I found a solution to the Black printing problem :)
Under Printing Preferences: Set your Media Type to Photo Paper Pro.
We used edible ink cartridges and printed onto icing sugar paper. Same old... Just one day it refused to print black. In order to continue our small business, I degraded the color until I printed gray and not black.
Tonight, I browsed for the problem and came across this :)
Hope it helps you too
Nov 22, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print black
first of all the most important auestion is have you used compatible ink cartridges or genuine ones, because the print head clogs up with compatible ones, i really doubt that the cartridge you installed is damaged because i haven't come across this and i am a canon technician, i know this model well
Nov 02, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
222 people viewed this question
jasbo
jasbo
