Back to:
Tags:
Scott SPS1 System
SPS1 charging system
posted by Jeff1 on Jul 30, 2007
SPS1 portable speaker system does not keep 12V battery charged even with AC adapter plugged in continuosly. Once the battery goes dead after about 2 - 3 hours, it never charges back up to a usable state even when plugged in and left off overnight. However, I can charge it with an external 12V battery charger, and the battery will last another 2 - 3 hours. I bought a new battery thinking that was the problem, but the problem is still there. When purchased new, I could run the system continuously beyond 5- 6 hours and never had a problem.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
halvibe
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Borrow a multimeter and check the voltage (and current if you can) going to the battery while the unit is turned off. It should still be charging the battery if it's still plugged into the wall socket. If it is not getting about 13 volts, it's not going to charge the battery. If that's the case, then there's something wrong with the transformer, or another part of the charging circuit. The downside is you can't use the unit without the battery being connected. If the unit still works and sounds good even though it's not charging the battery, then just put the battery on a separate charger every week or so.(I use the SPS1 for my computer and love it!)
Good luck with it.
H.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on SPS1 charging system:
I don't want to Accept this solution
Can you Help with these Home Theater Speakers and Subwoofers problems?
Problem is T6060 comes with the three pin which are...
I want to replace the speakers in my towers and i need to...
I only get sound from the Direct and Stereo settings on my...
Scott SPS1 System
turned on speakers the is no power they are plugged in and...
Scott SPS1 System
I have a problemm with speaker scott sps1. subwofer...
Loading problems.
Repair Service
Find Home Theater Spe. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
