Question about RCA HD52W59 HDTV Projection Television
Tv won't autoconverge and color right - RCA HD52W59 HDTV Projection Television
  • RCA Master
  • 8,617 Answers
Go the following link and leave them a email with the model number and symptom, they have the parts you need for the issue and they will help with instructions on how to repair the issue,
http://servicemanuals.vstore.ca/
Posted on Jan 31, 2009
Tv has a red color, will not autoconverge. what could be wrong?
glyons547,
See my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics for a solution to your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Jul 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The auto convergence not working, the colors not lining up together
Try this with TV off Press and Hold CH- and Vol- at the same Time untill TV comes on then release ,Now you should be in factory settings,set should do AutoConvergence .
Oct 31, 2010 | Zenith R49W36 49" Rear Projection HDTV
Colors out of whack on projection tv
You need to run autoconvergence in the menu screen. If it doesn't work, you may have to clean the lenses.
Mar 07, 2010 | RCA Televison & Video
COLOR IS SEPARATING
go into the menu of tv.find manual convergence,you have to adjust the red ontop green,blue ontop green.DO NOT MOVE GREEN.your set might have autoconvergence if it does activate it.let it go thru the process before doing anything.it should reach 100%.if it does not,you have a problem with the board.part number of the convergence board is 268820,you can replace it yourself.everything plugs in.
Sep 21, 2009 | RCA D52W23 52" HDTV CRT TV
3 color lines at top of screen no picture
If you do not see convergence in menu when you go to setup then you have a open fuse FL231 Next to flyback transfomer on right side there is 3 in a roll small brown rectanigler looking caps they are fuses the one in the middle is bad replace it .
Feb 11, 2009 | RCA R52WM24 52" HDTV Projection Television
Autoconvergence option is GONE!
You will need to replace the ITC222 convergence power supply board and the FL231 fuse on the deflection board. You can get replacement parts at the following link with free installation instructions.
Sep 24, 2008 | RCA R52WH73 Projection Television
There is a blown fuse and diode located next to the flyback transformer I believe the location is DL231 and the fuse is FL231
Sep 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52W23 colors not aligning
replace FL231 400ma located in front of FBT.This is what is wrong with your tv.
Mar 03, 2008 | RCA D52W19 52" Rear Projection Television
Convergence problems
convergence is fine on your standard coaxal cable input. and you can autoconverge that. you may have to autoconvege on you digital input
Jan 13, 2008 | RCA HD56W66 56" HDTV
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
