Question about GE 27GT619 27" TV
DVD player won't work on my 27gt615
I plug in the DVD player, and everything is connected but it won't connect through. I tried to program it to work on channel 2 then 4, but neither worked and I don't know what to do.
  • Anonymous Mar 06, 2009
    I have an old RCA Floor Model TV. With av and audio connects on back. I use the red/white/yellow cord to connect. But the DVD player won't play through the TV.
    Scholar:
    New Friend:
  • 70 Answers
Alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Posted on Jan 31, 2009
Dvd player on harddrive records but won't play back- connected with the one H.D. cable-sure there is a connection problem
Posted on Aug 04, 2009
How do i program my sony dvd player dvp.sr200p to work on my philips tv
No special programming is required. Connect the DVD player to the TV using an HDMI cable. Note which input jack you used on the TV (example: HDMI 1 or HDMI 2, etc.) Turn on the DVD player and insert a DVD disc and play it. Turn on the TV and select the input you used to connect the DVD player (example: HDMI 1 or HDMI 2, etc.). You should now see and hear the DVD disc playing. Most settings are pre-set at the factory so everything will work without adjustment. However, both the DVD player and the TV have a Menu where you can adjust settings for picture, sound, etc. if desired.
Jan 01, 2016 | Sony DVP-SR200P DVD/CD Player
Why is there no picture but sound?
Can you tell us a bit more about the problem? It would be helpful if we knew:
1) What device are you using to connect to Netflix (computer, DVD player, TV, etc.)?
2) When you use that device for something other than Netflix, do you see a picture? So if you're using a DVD player, can you play DVDs? Can you watch TV?
3) Can you log into your Netflix account on your computer and watch movies on your computer? Can you login from someone else's computer and try that?
3) When did the problem start?
Some shot-in-the-dark steps that apply to all electronics:
1) Turn everything off. Turn it all back on.
2) If that doesn't work, unplug everything. Wait 30 seconds, then plug it all back in.
3) Check all the cables (from power to your TV and Netflix device, cables coming from your peripherals to the TV, etc.). Even if they seem to be well-seated, unplug them and plug them back in.
4) Try new connections. If your TV was connected by HDMI, and you have a different way of connecting your device (DVI, component, RCA, s-video, coax, whatever) try it. If your device connects to the Internet wirelessly, see if you can get a wired connection. Swap cables wherever you can.
5) If you can, try interchanging components. So, for example, try connecting to a different HDMI port on your TV. Try other devices on your TV. Take your Netflix device (if it's not your TV) to a different TV.
Those last 2 steps may solve the problem, but are more likely to isolate the problem. (For example, if your DVD player doesn't work no matter what TV it's connected to, then the problem is the DVD player.)
Update us with as much info as you can.
Mar 29, 2015 | Netflix
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
Apr 21, 2012 | Sony Dvp-sr500h 1080p Upscaling Dvd Player
My legacy indash DVD player screen won't come on everything else is working fine
CONNECT YOUR BRAKE SENSE WIRE UP TO THE EMERGENCY BRAKE SWITCH LOCATED ON THE PEDAL, THEN ENGAGE THE BRAKE WALA!! IT PLAYS!
May 26, 2011 | Legacy LDTSN7 Car Video Player
Programming prob on GE TV model #27GT615
There has to be a signal on one channel at least below 50. connect a DVD player to the TV and try programming. You are supposed to have a signal on cahnel 3 or 4.i hope this helps you. thats all I can think about now.
Nov 03, 2008 | GE 32GT740 32" TV
Televison & Video Logo
771 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
