Question about Vehicle Parts & Accessories
Wiring diagram to hook-up remote starter on 1996 dodge caravan
  • fijiIslander Apr 28, 2009
    I got a 96 Dodge Caravan ....
    i hooked up everything the CD Player works , ejects, reads cds.
    but the problem is no sound will come out at all and wen the cd player is on after like 10 seconds later the speed domitors just go down.....what do i do i need to know ASAP please !
  • 15,935 Answers
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Jan 31, 2009
  • joel Nov 08, 2011
    hey i youst installed my prestige alarm in my fordescape but wen i lock the doors o turn it on with the remote starter the lights dont turn on
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Hooked up my terminals backwards on 1996 dodge caravan now it wont start ive checked all the fuses and still wont start
You have trashed a computer. Maybe all of them. Put a scanner on it and see which ones you can't read. These are dead.
Dec 12, 2014 | 1996 Dodge Caravan
How can i know if my starter relay is bad on a dodge stratus 2001
IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
Aug 28, 2011 | 1999 Dodge Caravan
Need to remove and replace starter on 1996 Dodge Caravan
quite simple and yet tough your first time
1.) install a memory saver
2.) disconnect the battery cables
3.) disconnect the wires at the starter
4.) unbolt the starter
5.) reverse to install
May 16, 2010 | 1996 Dodge Caravan
Transmission wirind diagram
i have 15 differrent diagrams depending on engine size and your requested circuit, please clarify
Nov 24, 2009 | 1996 Dodge Caravan
Replacing old stater in 1996 dodge caravan
For the starter, you just disconnect neg battery cable. Mark starter/solenoid wires, then remove them, then pull out the two starter bolts and drop starter.
You can go to www.autozone.com and register for free. It is full free online repair manual
Sep 09, 2009 | 1996 Dodge Caravan
Locate bolts to remove the strater of 1996 dodge caravan
Almost all starters have ears with holds in them that bolts go through to threaded holes in the bell housing. Find the starter and look around the end without the wires for the bolts.
May 07, 2009 | 1996 Dodge Caravan
Installing a ready remote starter
http://64.85.6.118/diagrams/diagrams.asp use this site to rekognize wiring harness at the ignition switch or related wiring
Mar 12, 2009 | 1996 Dodge Stratus
Need wiring schematics for a 1996 dodge caravan stereo hooking a new one up but dont know what wire is what theres no diagram on the stereo
Save yourself some hassle & buy the adapter to go from Chrysler harness to generic, from same place as stereo or any auto parts place that sells stereos/radios, should have them.
Dec 20, 2008 | 1996 Dodge Caravan
Vehicle Parts & Accessories Logo
1,382 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
