Question about Mitsubishi VS-50603 50" Rear Projection Television
I was watching it just went out
So I was just watching t.v. and all of sudden it went out. I can turn it on for about 3 saconds then it shuts off again. Any suggestions
Sometimes a static electricity build up will cause this to occur. Is the humidity in your house to low? Has the issue resolved itself?
Posted on Mar 26, 2009
Receiver suddenly turns off
If you have the vollume control set around 40, End watching a movie if there is a loud burst in vollume,It is causeing the reciever to run over it,s wattage rateing. End over heating,When it,s shuts down, It went into what is called the protection mode.Keep it at a lower vollume then it willnot do that.Allso what can cause it to do that, If you have your output leval control on your sub turn right up.
Oct 17, 2012 | Yamaha RX-V665 Receiver
Garmin 1490 lmt
Use a volt meter and make sure the voltage at the oulet inthe car is at least 12.5-13.8 volts DC
Apr 27, 2012 | Garmin Nuvi 1490LMT GPS Receiver
I have an RCA 52" screen TV and I was watching tv and all of a sudden the picture went blank and then the TV shut off. When I try to turn the tv on all i get is a scratching noise and then it turn off. can...
Hello again you need to Rate my solution other wise they are not going to pay me! since i did give you correct answer to fixing your TV ThanK You Replace 3 capacitors cp150 2200uf use 25v and cp114 cp120 220uf 35v.
Dec 19, 2009 | RCA HD52W58 52" TV
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Display problem
sounds like the internal video card is dying . have the service tech this out.
Mar 10, 2009 | HP Compaq Presario CQ50-110US Laptop
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Televison & Video Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
