Question about Refrigerators
Fridigaire side by side ice maker not dispensing
The ice maker works. The dispenser hums like it is trying to work, but the auger won't turn to push the ice. This happened after a power outage, when the ice in the bin melted slightly, the refroze like a chunk. HELP!
  • Anonymous Jan 31, 2009
    I have a Kenmore Model # 1069552811. The ice maker has suddenly stopped making ice.
I just fixed my daughter's frig with the same problem. The gear of both the box and the ice holder got water in the gear box and froze. This did not allow the gears to mesh and turn the auger. Clean the ice from both sides of the gears and try it. Works great now.
Rick
Posted on May 02, 2009
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice maker works, but won't dispense from the door. Motor turning, but no ice coming out.
Make sure the bucket is pushed back all the way so auger engages the motor. You may have to turn the auger by hand and push to line it up correctly.
May 10, 2011 | Refrigerators
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice is made but dispenser does not spin so ice wont drop
Hi, Remove the ice bin. With the freezer door open, push the door button and then push the ice dispener button to see if the auger motor is turning. If it does turn, check and see if there is something in the ice bn blocking the auger.
Please try this and let me knwo.
Thanks
Vic
May 24, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
The auger does not have the strength to do it's job when a lot of ice is in the way. You can defrost the icemaker with a blow dryer. It will be messy so be ready with lots of towels or a mop.
Once the unit is dry, spray the auger with PAM or some similar cooking spray. Then let it recycle.
You can temporarily prevent more fresh water from entering the ice maker by simply moving the wire arm to the up position
Jan 31, 2009 | Frigidaire FRS26R4A Side by Side...
Ice dispenser
Hi Wilday1, Sounds like you have a possible defrost malfunction. In this case the Ice maker motor may have become iced and cannot turn the auger. Tell me if you have frost buildup at the back of the frezer and ice crystals on the auger drive. If you do , then you need to remove the Ice makers motor and allow it to thaw and defrost itself. be sure it is completely dry before putting it back in. I hope this helps.
Oct 08, 2007 | Kenmore 25.4 cu. ft. Side-By-Side...
Refrigerators Logo
331 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
