Question about Toshiba Computers & Internet
How to lubricate toshiba p100 fan
Toshiba P100 makes loud whirring noise for a few seconds on start up. Is 2 years old. Used constantly for business and moved around a lot.
  • Frank Stent Jan 31, 2009
    Thnak you. Until now any noise at this function has been unnoticeable. Last few days a loud whirring noise has occured.  Does it need attention or should I ignore'.
    Frank
  • 67 Answers
Your laptop is testing the fan at start up. The fans cannot be lubricated.
Posted on Jan 31, 2009
  • kev442 Feb 01, 2009
    I would be more worried if you don't hear the fan anymore! My old HP laptop has been loud for at least 4 years now.
How to check out or look for problems with the lcd monitor on toshiba satellite p100
The internal screen is faulty. Check the inverter first. (under the display).
Jan 20, 2013 | Toshiba Satellite P100-102 P100-103...
Toshiba satellite backlight
Mohammad,
Toshiba Satellite P100 screen Inverter replacement;
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
(You can click on any photo to enlarge it. At the top, and bottom of the page are the page numbers. They are in white; Page1 :: Page2 :: Find another model )
2) Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology) is a CCFL, or a series of LED lights.
The Toshiba Satellite P100 series of Notebook PC's uses a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average size is approximately 2mm Thick, and the length is close to the height of the LCD screen. 2mm is a little larger than 1/16th of an inch.
This means the CCFL can be broken quite easily, as it is fragile. (You also DO NOT want to be cut by a Fluorescent lamp )
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
As previously stated in a Clarification, 90 PERCENT OF THE TIME the fault is the screen Inverter.
Regards,
joecoolvette
(I never request commendations, but thank you for offering.
We, the older techs here, feel that is begging.
3 years at FixYa so far.
Regards,
joecoolvette)
Mar 23, 2012 | Toshiba Satellite P100 Notebook
My disc cleaner program does not work or run
Hello carm.... These cleaners have a limited life. When it will no longer run it is time to replace it. Joe
Thanks for choosing Fixya!
Jan 07, 2011 | Toshiba Satellite P100-102 P100-103...
Where can i get manual for toshiba satillite p100-240
online look it up on google !!! it's your best friend for all or just about any answer you might have ok:
type this in the search pane ok
(manual for toshiba satillite p100-240)
and you should be able to find one ok good luck and have a nice day the fixist !!!
Aug 02, 2010 | Toshiba Satellite P100 Notebook
Toshiba Portege r200 is making whirring noises
Its problem two things. One, the fan on the heat sink or your hard drive. More than likely your hard drive.
Feb 06, 2010 | Toshiba Portege R200 Notebook
Need to know how to dismantle Toshiba Satellite P100 to clean and check heatsink and fans, unit keeps overheating and shutting down thanks gene
Here is Toshiba Satellite P105 (which is the same as P100) disassembly guide.
Just follow instructions by scrolling down, then go to page 2, 3, ...
Jun 10, 2009 | Toshiba Satellite P100 Notebook
I want to download sound driver for toshiba satellite p100
Go to Start/Help and search on "update drivers" without the quotes.
This should list a few search results on PCs HELP files for instructions on Updating Drivers.
Else, google "sound driver toshiba p100" without the quotes and look for Microsoft or Toshiba site in search results preferably, else a driver download site you trust.
Feb 23, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba P105 S6104
Hi Ed;
This is issue has resolution as it has been published on Toshiba's Official Support Website. It seems you need to go to an Authorized Toshiba Center. They have a special tool to re-flash your BIOS and it will resolve the issue. I am adding the original text and link for the solution below
Good Luck
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1827224xml&sliceId=&dialogID=24612375&stateId=1%200%2024610494
New BIOS fixes incorrect power-on password prompt Document ID: 98082329 Posted Date: 08/21/07 Last Updated: 08/21/07 Category: ACPI, BIOS, Password Distribution: Public Applicable Models: Satellite P100-ST7111, P100-ST7211, P100-ST9212, P100-ST9612, P100-ST9412, P100-ST1071, P100-ST9732, P100-ST1072, P100-ST9762, P100-ST9772, P100-ST9752, P100-ST9742, P100-ST9712, P100-ST9012, P105-S921, P105-S9312, P105-S6074, P105-S6034, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6024, P105-S6054, P105-S6014, P105-S6004, P105-S6012, P105-S6002, P105-S931 << hide Use of any software made available for download from this system constitutes your acceptance of the Export Control Terms and the terms in the Toshiba end-user license agreement both of which you can view before downloading any such software.
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 4.00. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com.
Jan 11, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
264 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
