Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman chain drive opener won't stay down
My craftsman garage door opener will go down but when it gets to the bottom it reverses and goes back up unless I stop it with the remote or switch. Is there an adjustment for this problem?
  • John Holverson
    John Holverson Jan 31, 2009
    I tryed the adjustment screw with now Thanks for your help but it looks like a new opener.
  • John Holverson
    John Holverson Feb 01, 2009
    I tryed the blue adjustment screw again. previously I turned it up part way with no results then all the way with no results. This time I backed it up just a little from max and it worked ok. Thanks again for the help.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
Check the down limit:
If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing the garage door).
Check the up and down force:
On your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Posted on Jan 31, 2009
We have installed the craftsman garage door opener and have continually adjusted the up and down travel limits and the door will not stay down
try adjusting the down force. the force necessary to may it reverse. it may be set too light. increase the down force and see if that helps. usually screw in back of unit. and usually labeled.
Jul 24, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
I have a 1/2 hp crftsman 41A4315 garage door opener. I changed the gear and now it won't close all the way. It started going down and reverse back up
your chain is in the wrong position, unhook the chain and run the door opener so it is in the down position, then reattach the chain and make the adjustments as needed on the up and down screwes located on the side of the unit. good lick
Jun 21, 2012 | Chamberlain Sears Craftsman 950cb 953c
My garage door sometimes gets stuck and then goes
Don't tighten the chain. It sounds like you have either a broken door spring or the drive gear in the motor unit is going bad. Release the opener from the door and operate it by hand. It should be easy enough to raise that your wife can do it with no problems and it should stay put when released about waist to shoulder high.
Jul 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Door goes down and when it reaches the bottom, it ...
If the door hits the garage floor and then reverses to the open position you need to adjust the 'down limit' which is on the side of the motor unit. Turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
My older Craftsman garage door opener comes down about 6" & then goes back up. I just replaced all the rollers o& the opener worked fine. Then I tightened the chain on the opener & it worked ok...
If the main light flashes 10 times when the door goes back up it is a door sensor problem. You chain should sag just a little. If you tighten it too much it will click as it goes over the sprocket. You can increase the down force which is an adjustment near where all those white wires go. A 1/4 turn should be enough. Release the door from the opener and operate it by hand. It should move freely and when you have the door approximately waist high it should stay put. Neither raising nor closing.
Jan 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP chain drive garage door opener.
You need to take the cover off the motor unit and watch how the limit switch assembly works. If the door is not stopping when the contacts make then you have a bad logic board.
Jun 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2HP Door Opener won't stay closed
Loosen the chain and run the opener until the sprocket runs in the counter clockwise direction and stops. Now with the door in the open position replace the chain. This will get everything back into sync but I hope you remembered where all those controls were. You need to put them back in their original positions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener problem
If the safety eyes are not connected you need to ho;d the button down until it reaches the close linit.
Feb 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
917 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
