Question about IBM ThinkVision L170p 17" LCD Monitor
ThinkVision L170p wont turn on??
My friend gave me his IBM monitor to look at because it wont turn on. the ac cable is securely connected in both the monitor and the outlet, and the indicator light is solid green. but when i press the power button, or even hold the power button, it doesnt turn on, or do anything for that matter.
any help u can give me??
2 Suggested Answers
  • 3 Answers
SOURCE: IBM ThinkVision 17
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Posted on Dec 01, 2009
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
It doesn't show the image from computer, the screen still black but the power light appears on.
Connect another monitor to the PC and confirm that the PC is working , specially the display drivers/card. If so the fault is only with the monitor and it can be related to power supply issue, a backlight inverter circuit shorting or a fault in the main board., all of this mightt require a good probe with the use of manual. So please check this out and confirm if the fault is with the monitor or the PC.
Oct 18, 2011 | IBM ThinkVision L170p 17" LCD Monitor
Monitor IBM thinkvision 6734-ACO 17", turn OFF
Sounds to me your high voltage powersupply is out. To repair open monitor and remove high voltage powersupply. Inspect the caps on the board. Look for the ends of the caps to be mushroomed out. Replace these caps, usally 470 uf caps. Replace with 25volt caps. Might also be some 100uf caps as well. This is a common problem with all LCD monitors.
Jul 22, 2011 | IBM Computers & Internet
Where to get a driver for a IBM THINK VISION L170P
There is no need to install Dirver for Monitor
Only you have to install the graphic chipset Driver
then The problem will be solved.
Apr 02, 2010 | IBM ThinkVision L170p 17" LCD Monitor
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
LCD flat panel monitor blinks logo over and over
Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
IBM thinkVision
Could be the invertor board is bad and will need replacing.
Jun 16, 2007 | IBM ThinkVision L151 15" LCD Monitor
IBM ThinkVision L170p 17" LCD Monitor Logo
173 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
