Question about Refrigerators
We have whrilpool fridge top mount the water from the freezer is not draining to the pan below it is ending up in the bottom of the fridgewe have melted the ice to the drain hose but in aweek or so does the same
  • burns16 Jan 31, 2009
    how do you clean it or how do you replace it . what you have to take apart to get at it
    Sergeant:
    Champion:
  • 373 Answers
See if you can replace the hose ot clean it out
Posted on Jan 31, 2009
  • jim beckwith Jan 31, 2009
    if it like mind it is behind the panel that stick out and you willsee th hose the panel is in the back.
    I hope this works
The bottom of my fridge is filling up with water. I noticed its leaking from the top back of my fridge. Someone suggested its a condensation problem.
Check the drain tube that runs from the freezer to the drain pan, my guess is that its plugged with goo, connect a bulb like you use to asperate a child nose ect and see if it plugged, you can use hot water from the drain pan end and force the water up forcefully to break it loose or you may have to remove the bottom pan in the freezer and clear the drain. If its got ice built up blocking the drain then use hot water to cut the ice and clear the drain first if possible, then the water pan will catch it, but don't let it over flow.
Jun 26, 2011 | Kenmore Top Freezer Refrigerator
I have a no frost frigidaire fridge and recently when it defrost it goed at d bottom section of the fridge
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 22, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Hi there is water collecting in the bottom of the fridge. Have defrosted fridge/ freezer but water still collecting at bottom of fridge. Thanks
Mar 12, 2011 | Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Water collecting in bottom of ariston fridge
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 04, 2009 | Refrigerators
Water gathering at bottom of fridge.
Aug 25, 2009 | Samsung RB215LASH
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
