Question about Yamaha DSP-A1000 5-Channel Amplifier
Problem with Yamaha dspA1000
When I try hooking up My vcr to it to get sound for projector, I cant control the sound with the amplifier. Only the vcr. Do to the lots of hookups on back, Im hoping I'm just hooking it up wrong!
    Scholar:
  • 93 Answers
Be sure you are using the AUDIO OUT on the vcr then going into a AUDIO INPUT on the DSP A1000, this will allow the DSP A1000 to amplify the audio line level.
Posted on Jan 31, 2009
How to connect a turntable connected to a yamaha a450 stereo amplifier...can I attache the a450 to the htr-6130 ?
If the turntable is newer kind you can connect it in any Stereo input like CD, VCR , etc.
If the turntable is older model you can only connect it to PHONO input (if amp has one) and make sure earthing cable is connected on Amp
Remember input is only stereo (unless your model has digital input) and select sound effect eg Pro Logic for enhanced sound,
Aug 26, 2014 | Yamaha HTR-6130 Receiver
Yamaha YAS101 sound bar does not work on DirecTV remote control
Try this solution:
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/?current_page_id=1&sort=undefined&type=
Jun 22, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
I have a ps3 coonencted via HDMI to a Yamaha rx-v667. When viewing in a Sony TV, connected via HDMI to the amplifier, everything OK. When I want to have the output to a VW10HT projector connected via RGB,...
It could be your cable is too long and the attenuation is too much.
Can you use the same lead that you did for the TV ?
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sony VPL VW10HT Multimedia Projector
Subwolfer does not play with cd's, plays fine with dvd's
Some amplifer's have controls to switch subwoofers off in some modes. Have you accidently switched it off?
Dec 13, 2009 | Yamaha Digital Sound Projector Home...
How do you hook projector up to sound system
it is best to bypass the projector and have all audio going through an amplifier and speakers separate from the projector, and also, only have video going to the projector
Jul 12, 2009 | NEC VT60LP Projector Lamp for VT660,...
How to hook up cable from the wall to epson ex30 projector
The Epson is a monitor only. It has no tuner, so no cable connections. If you have a cable box or VCR, or DVD with RCA Style Connectors (yellow, red and white) connect your cable coax to the box or VCR and then the video and audio outputs on the box or VCR to the projector and select the video mode.
May 28, 2009 | Epson Televison & Video
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
How do I hook my data projector up to my cable TV?
If the TV offers video and audio outputs, you can connect those to the projector. Otherwise you'll need to use a VCR or DVR as the source. In fact, you don't need a TV set at all if the VCR/DVR you use has TV tuning. Hook the video to the projector, run the audio through your stereo system and you're set.
Jan 28, 2009 | Sanyo DS25390 TV
Ctx 6180
It will work only if your TV has a Video OUT either in Composite RCA, S-video or in some other form although not all TV models have this feature.
Alternately, you can hook up your projector to an old VCR which definitely will have a Video OUT and use its built-in TV tuner. Of course you have likewise to connect a cable/aerial to the RF IN of the VCR.
Hope this be of some help/idea. Good luck and kind regards.
Oct 27, 2007 | CTX UltraVision PS-6180 Multimedia...
CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Oct 23, 2007 | Office Equipment & Supplies
Yamaha DSP-A1000 5-Channel Amplifier Logo
232 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
