Question about Canon imageRUNNER C3200 Copier
Toner streaks Thanks for the help here guys. I have a Canon C3200 that has been putting random streaks on random pages. It seems to be all colors, except black, but it could be in there as well. I have installed four new drums, a new fuser assembly and replaced toner. Once I did all this I figured I'd be off and running... not so fast. The cyan drum appears to have been defective since it was ''dumping'' toner on the backside of the belt. I put the old one back in and it corrected the problem. Now what I am getting(which was my original problem before I replaced everything), and it can be any size, anywhere on the sheet, is a CMYK streak all the way across the page, but not all the way down the page. I also get a 3/4'' streak down the middle from top to bottom with alternating colors... These prints of extra toner look like they were swept by a broom, or in this case, a wiper of some sort. Is there a wiper I should replace? Or is it something else that needs replacing? Last week I printed a black and white document and didn't have any of these issues, so I figure the black is okay. The machine only has 131k on it, so it's not like it's worn out. And by replacing all of the aforementioned I figure I'm pretty close to a pretty new machine anyway... ha! This whole issues is probably something simple that I could have corrected with something off an infomercial for $19.95, maybe that Billy Mays guy has something I can use, or perhaps a SHAMWOW! is in order?
    Sniper:
  • 57 Answers
You have to change a sensor. This sensor is on the left hand side of the machine. To know which sensor you have to open the left door and not take out the fuser. The sensor monitors opening and closing of this door. Make sure you change this one with a sensor that has the full black plastic. There is nothing worng with this machine except than this sensor.
Posted on Jan 31, 2009
Streak along edge of paper, Canon MF8380Cdw
Print quality issues on these models is usually if not always down to the cartridges used. I bet you are using compatible cartridges. If so just buy a set of genuine ones and I bet the quality will be perfect again.
Jun 01, 2016 | Canon imageClass MF8380Cdw Wireless Color...
Color streaks after gradation
sounds like you need a new magenta drum
Jan 14, 2014 | Canon imageRUNNER C3200 Copier
Brother HL30-40CN - Streaks down the every page
On my black and white toner printer I wiped the drum off with a rag and it solved the problem.
Dec 07, 2013 | Brother HL-3040CN Color Laser Printer...
E000020 01b0
Yellow Drum Cartridge or bad toner. If your using generic toner it can cause this code. If generic toner is used drum cartridge unit will have to be replaced and Canon Genuine toner used instead. Yellow seems to be more suseptable to this than the other colors for some reason.
Nov 25, 2011 | Canon imageRUNNER C3200 Copier
My Canon PC-25 copier is streaking
Toner cartridge is defective - replace it
Apr 06, 2009 | Office Equipment & Supplies
Problem with printer
Have you tried a new magenta cartidge. I think it has run out, that'swhy you can only print black
Mar 23, 2009 | Canon imageRUNNER C3200 Color Printer
Canon ir c3200 promts for page setup on each internet document
I believed when page setting box show out you have to enter the quantity you want print
Dec 09, 2008 | Canon imageRUNNER C3200 Color Printer
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Canon Imagerunner c3200 copier problem
Sound to me like a drum problem, try replacing it and it should work after u do..
Nov 28, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Copier Logo
157 people viewed this question
old marine
old marine
