Question about SanDisk Sansa c240 MP3 Player
Battery my battery will not take a full charge since the first day i have had it can you tell me what to do?????? it takes a half charge and dies in 2 hours
    Scholar:
  • 67 Answers
Most likely you need to replace the battery. If it's still under warranty Sandisk will replace it. Otherwise you can buy a new one from their website. Here's the link. http://www.esend.com/sandisk/Products.aspx?Catalog=Sandisk&ProductID=SDAMX7-RBK-G10(Esend)# If the link doesn't work just go to www.sandisk.com and look under products, audio accessories. Looks like $19.99 plus shipping for a new battery.
Posted on Jul 30, 2007
    Sniper:
  • 133 Answers
Sometimes you just get a bad battery and sounds like you are one of the unlucky ones. Get a new battery using the DIGITAL batteries. last longer with electronics
SOURCE:
Ps4 controller not full charging
How old is your controller, maybe your battery is dying. Try opening your controller and replace it.
Jan 09, 2014 | Lands Phones
My battery takes upwards of 5 hours to charge sometimes which causes a lot of issues since I travel a lot from work via train (hour and a half commute each way). When my battery dies during the day, b
Honestly nothing. You'd be better off just buying a spare or two. That way you will always have one to use while the other charges. There is newer graphene battery tech coming out that charges in minutes, but it isn't ready for consumer products yet.
Nov 18, 2013 | HTC One
AFTER HALF HOUR MY BATTRIES ON MY MOBILITY SCOOTER SHOW GREEN
Could be - I would take the scooter or battery to a car store and they will load check the battery - That is, they will cause the battery to do work, and measure the voltage.
Measuring volts while the battery is at rest will indicate full voltage. That would be a flawed test.
Dec 30, 2012 | Health & Beauty
The last 3 days, my battery lasts only a few hours. It used to last at least 15 hours
Battery and Usage under Settings will tell you exactly what is draining your battery. You should power your phone off for a few minutes every 2 or 3 days.
Also try letting the battery die completely, and charging up to full UNINTERUPTED. This will help the phone reset it's battery meter, which may be the problem.
Your next step would be to backup the phone, apps, and SD Card files, and perform a factory restore. Then reinstall your apps and replace your data.
If that fails, you may simply need to purchase a new battery.
Apr 13, 2011 | HTC Hero Smartphone
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
It wont keep a charge, the battery dies way to fast, it wont charge it with the cigarette lighter, or the house charger. once i unplug it it dies. I replaced the cigarette lighter and the home charger, and...
rechargeable batterries fade with age, neglect or misuse. Your battery is almost 2 years old from the time you purchased it, (probably 6 to 12 months older), so could indeed be dying. I just replaced a phone in my cell phone that was holding a charge for less than a day. The replacement from batterybuyer dot com fixed the problem and now my phone stays charged for 3 to 4 days.
Open the case of the GPS unit and the battery will have its specifications marked on it, usually a serial number and voltage, plus capacity in Milli-amp hours.
Nov 17, 2009 | GPS
Shows full charge but dies within one song
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you have over charged and drained completely , the battery must have been busted.please replace the batteries and if still isnt turning off, check the keypad for any faults.hope your problem is tackled..have a nice day
May 22, 2009 | Microsoft Zune JS8-00001 Digital Media...
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
LG charging problem
try to change battery first!
Oct 28, 2007 | Cell Phones
SanDisk Sansa c240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
