Question about Sanyo DWM395 DVD Player
My disc drive
Im trying to put a dvd in my dvd player and when i try to open it it says the disc drive is locked, and i dont know how to unlock it.please help me
  • 661 Answers
Press and hold the eject button until the system reports it is unlocked again This feature was designed to be a childproofing feature, to stop kids from inserting slices of ham or playdough into your player
Posted on Jul 30, 2007
Hello, I have jusy bought a HTS3011 home theatre system, but I had try to play a lot of dvd s, and I had an error related to the disc regionin the most part of the discs I tried. Can someone help me? As I...
Hello Patricia -
Please follow the instructions below for unlocking your Philips HTS3011
1. Switch on the DVD player
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the DVD player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Regards,
BElectric
May 01, 2011 | Televison & Video
Need a user manual for DRC6300N . Ours says"locked" and dont know how to unlock it
Try this page... they say they don't have the particular manual but it may help to unlock
http://www.retrevo.com/samples/RCA-manuals.html
Lock/Unlock DVD player
• To lock player, open tray and press SETUP, 0, 0, 0, 8, 3 (an on-screen message, "Key
Lock On" is displayed).
• To unlock, press SETUP, 0, 0, 0, 8, 3.
This from another RCA manual but may work
Cheers
mickypics71
Sep 17, 2010 | RCA DRC6355N DVD Player/VCR
Trey locked
There is a lock on this on the remote or end the menu system I do not remeber witch. You can unlock this software if not you need to unlock it hardware witch gets a little tedious.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Sony DVP-NS700P DVD Player
DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Apr 03, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Philips dvp 5992 Disk drive wont open
HELLO MY NAME IS ANDREI
I THINK YOU MIGHT OF LOCK THE DISC. BY DOING THIS YOU BLOCK THE PLAYBACK OF THE CURRENT DISC. SUBSEQUENT ACESS TO A LOCKED DISC REQUIRES A SIX DIGIT PASSWORD THE DEFAULT PASSWORD IS 136900. THIS WILL UNLOCK THE DISC LOCK FEATURE. MAKE SURE YOU GO YO SETUP AND CHOOSE UNLOCK DISC LOCK PERMANENTLY OR IT WILL KEEP DOING IT EVERYTIME YOU PLAY THE SAME DISC. HOPE THIS MIGHT OF SOLVED YOUR PROBLEM.
Jan 15, 2009 | Philips DVP5990 DVD Player
I have a jvc th-p7 cinema system. and when i try to open the tray it say's locked. but i dont know how to take it off?????
You can lock the tray and prohibit the unwanted disc ejection.
On the center unit ONLY:
While the system is turned off
• The system turns on and "LOCKED" appears on the display
window.
• If you try to eject the disc, "LOCKED" appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and "UNLOCKED" appears on the display
window.
Nov 27, 2008 | JVC Televison & Video
Displays lock when trying to insert a disc
you need to find the unlock code for it. check the web site for the model number that you have and look for the unlock code
Jul 13, 2008 | JVC XV-S302 DVD Player
Dvd tray is locked and i cant find the manual to unlock it.
Press the open button down for 5 sec and the dvd player will say unlock and then you can hit the open button and the tray will open. I just did this. IT WORKED YEAH!!!!
Jan 31, 2008 | Sanyo DVD-SL20 DVD Player
Sanyo DWM395 DVD Player Logo
119 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
