Question about Garmin zumo 550 GPS Receiver
Manage Trip Log
When i go the Manage Trip Log and select Save As Route the unit just sits there with Calculating 0% on the screen and after ten minutes it is the same . How do you save as route what am i doing wrong
  • 3 Answers
You cant save it this way
When u finished riding the route, save it then (remember to clear the log before you depart)
Posted on Oct 19, 2007
  • Bollie Oct 19, 2007
    To get to it then its quite a process:
    1) Connect to the Zumo with PC
    2) Find on Zumo the file Current.gpx
    3) open it with PC's MApsource progman into a new map file
    4) Under Tracks the log will be visible
    5) Rename the log
    6) Copy
    70 Opn yr usual Mapsource map file
    8) Paste into Tracks
    9) Save file
    10) Tfr to Device, only Waypoints and Tracks
    11) Disocnnect device, when it boots, manage data, import tracks
    12) THEN this track wil come up as a route on device
    Sniper:
  • 133 Answers
Http://www8.garmin.com/manuals/1369_OwnersManual.pdf page 16
Posted on Jul 30, 2007
SOURCE:
How do i change the base of a log
The calculator can only calculate logs to base e (ln) and ten (log).
However you can calculate the logarithm of x to any base b simply by calculating ln(x)/ln(b) or log(x)/log(b).
Apr 09, 2014 | Casio FX991MS Scientific Calculator
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
When i push to calculate route the screen gets stuck on "calculating" and won't do anything.
You have a corrupted trip.db file.
1. connect the TND to the computer and turn the TND on.
2. go to your start menu and press on (my) computer
3. look for an external drive called intelliroute.
4. look on the drive(s) for a folder called Navi
5. double click on the Navi folder.
6. You should see a folder called User.
7. double click on the user folder.
8. You should see a file called Trip.db.
9. left click once on trip.db, then right click and delete.
10. disconnect your TND from the computer and enter a route in.
it should operate fine now.
Thanks,
Mark, Rand Lead Beta Tester
Sep 13, 2010 | Rand Mcnally TND 500 Car GPS Receiver
Cannot save direcctions to my gharmin 260w
Unfortunately the Garmin Nuvi 260W lacks the capability to save a route. If you are looking for a unit with great Trip Planning (route saving) features, the new Garmin Nuvi 3790T is a great option. I am currently using one and I love it.
Cheers
Jul 14, 2010 | Garmin nuvi 260W GPS Receiver
Keeps recalculating route and rerouting
This may or may not help you.  If you are in area where the unit cannot get a signal it will tell you recalculating or if you are in area where it's maps are not up to date it may tell you the same thing. One other possible solution, shorten the trip, on a long trip the unit will/might find several possible routes and based on your settings it is unable to select just one route so it is choosing between two at the same time and it will keep recalculating until circumstances allow it to decide on just the ONE route.  Change some of your settings in the setup screen and see if that helps or if it is a long trip, break the trip up into smaller segmants. Hope this helps
Jun 01, 2010 | Tomtom ONE 130 GPS Receiver
Tomtom One not doesn't calculate arrival time correctly.
thats normal- estimate is always higher the units go by speed limits and you shave time off trip units adjust accordingly
May 18, 2017 | Tomtom One XL GPS Receiver
Zumo 550 Trip Log
In one of the menu's you can select the trip log to be visable, press wrench, press map, press to the right of triplog to switch from visable / hidden. press back, press user settings and there is manage trip log. BTW all this info can be found in the Fine Manual!
Oct 15, 2007 | Garmin zumo 550 GPS Receiver
How to program a destination
In general, once you key in an address and then select a route, the name/route will be saved in "recent destinations." If you want to use that destination, just select it. If you want to add it to "Favorites", then select "Add Favorite" and all your recent destinations will appear. Select the one you want and rename it: E.g., instead of "220 W. Walnut St." rename it "Grandma's House" and it is set.
Oct 08, 2007 | Tomtom ONE GPS Receiver
Garmin zumo 550 GPS Receiver Logo
324 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
