Question about Virtual Reality Sound VR3 CD Player w/ USB and Scan Disk Inputs
Vr3 installation where does the brown wire - labled parking brake - go
It's supposed to go to the wire of the parking brake that is grounded with the parking brake on. This wire disables the dvd video so it can only be watched with the parking brake set. On mine, I just connected it to the black wire so it is able to play video all the time. Or you could run it directly to ground, same thing as connecting it to the black wire.
Posted on Feb 21, 2009
Ground it..
Posted on May 02, 2009
VR3 cd 400 where to get wiring plug to go in back of player
Do you need a wiring harness for the back of the unit? All you have to do is google "wiring harness for vr3 cd400 and you will have allot of options to choose from. If you connected the red which is 12v +, yellow connects to 12v for radio memory, and black goes to ground. Brown is for external amp turn on. Check to make sure your connections are correct. Do you have an adapter harness that plugs into the factory radio harness? You can get one from Wal-Mart or best buy or online. So you don't have to cut/splice into the wiring harness coming from the stock radio.
Aug 25, 2017 | Virtual Reality Sound VR3 CD Player w/ USB...
VR3 640g roadmaster won't "power on".
Sounds like it is broken. If you have the power wire hooked up as you said it should be working fine. Not sure which browm wire you are referring to but it should work regardless of that.
Mar 03, 2009 | Virtual Reality Sound VR3 CD Player w/ USB...
Bypass parking brake for VR3
Hi, I had the same prob with mine. Pretty easy fixed. There is an earth wire connected to the park brake switch, you have to disconnect it. If you are not savvy with car stereo installation, I would advise you take it to strathfield or another car stereo installer - it is a quick and easy job and they shouldnt charge you more than 20 bucks for it.... if that. Beware though, playing movies in your field of view is VERY distracting and dangerous..... and illegal.
Jan 16, 2009 | Jensen VM9510 Car DVD Player
VR3 VRVD630 dvd bypass instructions/codes
I also just bought a VR3 DVD -CD PLAYER MODEL# VRVD630 ALL I DID WAS CONNECT THE BROWN PARKING BREAK WIRE TO THE GROUND WIRE THAT LETS YOU WATCH DVD WHILE DRIVING HOPE THIS HELPS
GOOD LUCK STROUP
Nov 27, 2008 | Jensen VM9510 Car DVD Player
No running lights when head lights are on
the brown wire on your suburban will be your park lights and the yellow will be brake/turn are you sure the green wire is ground on your led lights? i would think the black wire would be ground
Nov 25, 2008 | 1988 Chevrolet Suburban
How do i bypass the parking brake switch in order for my video to play
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jun 25, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
Usb problems, DVD Issues,and Radio volume problems.
connect the breaking wire(brown) for model VRVD630 to a ground (i just connect it with the black) meaning ground wire black and breaking wire brown will run too the same ground wire which will show up your dvd screen and it wont b blank
Jun 10, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
Safty brake feature
k here's the thing. The weird wires for your safety brake, headlights, etc.
If you want to be able to use your player while driving, aka leave a movie playing and have the screen still work then ground those wires. You could either splice them into your ground wire or you can take and use the sheetmetal surrounding the head unit to ground them.
Oh and as for the reverse light wire. That one you will need to wire in if you're going to use the optional reverse camera that they sell separately.
Hope this helps, don't forget to click fixya! :)
Feb 20, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
HOW TO UNLOCK MY VR3 RADIO TO PLAY DVD MODEL VRVD630
The brown wire labeled parking brake -12v should be connected to the parking brake switch. So that to watch a DVD the parking brake needs to be set. but can be bypassed by connecting to ground.
if connected to the lights it could be your problem
nels
Oct 16, 2007 | Kenwood KDC-MP228 CD Player
Brown parking line
4 months and nobody answered this for ya?? This unit is designed to prevent video operation while the vehicle is in motion, connect the brown parking wire to the parking brake indicator. Or, to bypass the safety application, simply connect the brown parking wire to the ground wire.
Sep 02, 2007 | Lanzar STV71 In Dash 7" Color LCD TV Car...
Car Audio & Video Logo
476 people viewed this question
Top Virtual Reality Car Audio & Video Experts
Mark Skinner
Vladimir Frolov
Are you a Virtual Reality Car Audio and Video Expert? Answer questions, earn points and help others
