Question about Nintendo Super Mario World for Super
SNES Cartridge Needs Battery Replaced
My SNES Super Mario World isn't able to save game info anymore. I've been told that the battery needs to be replaced, and that I may need to do a little soldering.
  • 52 Answers
Borrowed from racketboy.com :
What You Need:
  • 3.88 mm security bit. You need this to unscrew the funky hexagon-shaped bolts on SNES carts.
  • A SNES Game Battery (aka an CR2032)
  • A basic soldering iron, nothing fancy. I bought a kit at radioshack for $8, came with a 45-watt iron. (You COULD also just tape the battery in instead of soldering)
  • An X-Acto knife, or some kind of scraping razor. It justneeds to be a VERY thin knife, one you don’t mind getting stained up. A kit with a variety of blades can also be found at Radioshack, Wal-Mart or craft stores, for around $4.
  • Some Electrical tape.
SNES Game Battery Swap Walkthrough
  1. SNES Cartridge Needs Battery Replaced - snes-ad1.jpgClean your hands thoroughly first.
  2. With your SNES cart lying face-side up on a table, you’ll see the two hexagon bolts on the bottom two corners. Use your 3.88 mm security bit to remove these bolts.
  3. Lift the cart’s front cover by pulling up, toward you. You’ll see thebackside of the game’s board. Lift the board out. Try not to touch anythingbut the edges any more than you have to.
  4. On the other side of the board, you’ll see the battery on the top left corner, a silver circle about the size of a nickel. The battery is soldered onto connectors above and below, at two points on each connector. The next step is to break these solder points (carefully!) (Edit: I have found that my copy of Final Fantasy 3 has 4 solder points on each side, but all my Nintendo made games have only 2. YMMV.)
  5. If you plan on soldering for the best connection (otherwise, skip to part 8), plug in your soldering iron, wait for it to heat up(it’ll change color when it’s done.) Set your razor against it, for a minute or 2. Slide the hot razor between the battery the top connector, push it against the first solder point. You will need to find a safe and comfortable position to push from– you will need a bit of leverage, but also be careful of your fingers and chips on the game. Be VERY patient– with enough reheating, pushing, and some cutting, the first point will come loose.
  6. You have two choices– either repeat the process on the second point, or attempt to “wiggle” it loose. If you choose to wiggle it, be very careful not to snap off the connector or bend it completely out of shape. A little bending is fine.
  7. For the bottom connection, cut the first connection the same way you did the first. For the second connection, wiggling is less risky since it’s the last one, but still be very aware of what you are doing and be patient. Each game is soldered differently, so make your best judgement call.
  8. Either solder the New battery back on if you know how or tape it into place. To tape it, take a 2 inch piece of tape and place it under the bottom connector. Place the battery in between the two connectors and wrap the tape around it as tight as possible. You can even double up the tape, to make sure the battery won’t go any where.
  9. Turn the board back over (battery-side down) replace it into the back cover of the cart. The slots it fits into are arranged so you won’t be able to re-insert it upside down, so if you’re having trouble putting it back in, turn it over!
  10. Place the front cover of the cart over this. Remember the hooks that slide into the back cover? They make it so you have to angle the back cover down & away from yourself. Replace the 2 hexagon bolts. If the board still rattles, you might need to tighten the bolts down a bit more. If you taped the battery in, it’ll probably be a snug fit.
  11. Pop the game into your SNES, play long enough to save. Turn the machine off, take the game out and throw it around. Tap it on a table, drop it, rattle it, be rought with it but don’t break it! This is just to test how secure your battery is in there. If you plug it back in and still have your save, congrats. Chances are, your battery is secure for the next 10 years.
Posted on Feb 13, 2009
Super Mario world cheat code sites for super nintendo Please help me out peaple Thanks
Try www.gamefaqs.com/snes/519824-super-mario-world/cheats
For Super Mario World on the Super Nintendo, GameFAQs has 8 cheat codes and secrets.
Mar 17, 2015 | Nintendo Video Game Consoles & Games
Hi i bought a fc twin and all work great but super mario world just dont work do you know why is only this game?
For some reason, not all games work on the fc twin. Some game have chips in them and others small batteries like a watch battery for saving. Go to wikipedia.org/wiki/fc_twin for a little help. I looked up that game and it says its compatible so maybe a damaged game. Good luck.
Nov 01, 2012 | YOBO Video Game Consoles & Games
How do I get past Vanilla Dome 4
There is no Vanilla Dome in New Super Mario Bros for Nintendo DS. If you ar talking about the Super Mario World SNES version, you can see the instruction/tip on how to get past Vanilla Dome 4 here:
Vanilla Dome 4
You can rate my answer if you appreciate my help.
Thanks!
-damneddle
Oct 09, 2011 | Nintendo New Super Mario Bros. for DS
Game keeps losing memory .any way to stop this.mainly SUPER MARIO WORLD.
Well its because the battery that allows you to save the game data is dead now or is dying then.
1. NEW CR2032 3v Battery.
2. Onboard CR2032 Clip-in Battery Holder.*
3. Labor Charge For Installation.
4. Return Shipping Coverage
5. Lifetime Guarantee On Install (not battery obviously)*
* Game Boy & Game Boy Color batteries will be replaced with new battery only as there is no holder I have encountered small enough to fit inside a Game Boy cart.
Now changing your game save battery next time it dies will be as simple as just popping out the new battery and sliding a new one into the mounted holder! I am aware that some people may be able to do this themselves, and if you are technically inclined, then by all means pass this service up. However if you aren't, or don't want to take the risk of damaging your game, shoot me a PM. Thanks Everyone @ NA!
SNES cart with battery holder installed. Looks nice huh!? These holders sit flush with the board, and unlike almost every other one, DO NOT POSE ANY ISSUES closing the game.
NES cart with battery holder installed. Again, same as above, these sit flush with the board and pose no issues closing up the cart as normal.
Each game will also be tested to make sure games save properly several times before being returned to you so as to avoid redos and $ wasted for everyone on shipping. Thanks for all the interest everyone!
Aug 22, 2010 | Nintendo Super NES Console
My snes freezes when i play super mario world every time i get a coin or hit the blocks my game freezes. I thought it was the game at first so I bought another super mario world and It has the exact same...
Well maybe the console needs to be cleaned out esspecially if its filled up with dust and dander.
Dust causes video game consoles to over heat 10 times faster than their normal heating rates.
To clean out the console use a canned duster like for computers.
Dec 04, 2009 | Nintendo Super NES Console
SNES Sound but no Picture
either the wires could be shot or to an nes the same wires work but sometimes cause errors
Sep 18, 2008 | Nintendo Super NES Console
Snes super mario world
Was the game dropped or had any other damage afflicted to it? These things can happen if certain parts of the connector are chipped.
Oct 19, 2007 | Nintendo Super NES Console
Playstation Portable How to Down load Games
Hi Yoyoscoob,
You will need a WI-FI Signal to hook up to the internet. Then go to www.playstation.com.   They have free games , Screenshots, wallpapers, or more.  .  The URL above will take you to Playstation Underground, and you have to open an account.  They will send you good coupons to save  money on real in store games. Playstation Underground is the coolest site. Leave a comment if you need to know more on this topic, I will respond
Oct 14, 2007 | Sony PlayStation Portable (PSP) Console
Nintendo Super Mario World for Super   Logo
995 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
