Question about Sony VAIO GR370 Notebook
The wheel infront of touch pad is not functiong.
There is a rotating wheel nin front of touch pad is not functioning. What should I do.
  • 38 Answers
This is more then likely a driver issue. Sony likes to make devices that aren't 'normal'. Go to this address and try to find the driver:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGGR370
Posted on Jan 31, 2009
How to perform scroll function in laptop without mouse in Dell vostro
Your touch pad should do the trick.
They are called "Gestures". They are set to active by default. If it's not. Go to "Control panel > click "mouse" and find "touch pad". There you will find "Gestures". Activate it.
1. Put two fingers on the touch pad and try to move both fingers up or down. Learn how to scroll up and down.
2. Move those fingers side ways. This should do the "Horizontal" scroll.
There are others, like:
Put one finger stationary and rotate the other. This rotates the orientation of the object.
Try it and good luck.
May 23, 2014 | Dell Vostro 1510 Laptop
Acer aspire 5735 touchpad not working properly doesn't zoom
You can try updating the software for the touch pad but the most likely problem is you have a bad touch pad. Touch pads don't necessarily go all at once. You lose some functionality. In your case, it would appear you are able to to point and move the cursor. You didn't mention, does the touchpad respond when you tap it to hit ENTER instead of hitting the ENTER key itself. This is 1 area that will commonly lose function over time as well.
Nov 10, 2011 | Acer Aspire 5735 Notebook
I have a HP pavilion dv6000 and my problem is a sound problem i tried all settings they are fine on the touchpad the mute butten is red and whatever i do it staies red when i click it on the volume thing...
You have a multi function ribbon failure - the ribon that goes from you m/board to the special connector under the audio / quick launch chin panel infront of your screen
Jul 04, 2011 | Computers & Internet
I have new ProBook 4720s and the touch pad is locked? How do I unlock it?
You will have a push button just above the touch pad, if you push that button it will activate the touch pad...
Alternatively you will have the touch pad symbol printed on one of the function keys (f1 to f12), if you presss the "fn" and corresponding function key it will activate the touch pad...
Feb 06, 2011 | HP Computers & Internet
The cursor moves all over when I type and sometimes disappears sometimes all the text disappears and sometimes any key will close the program this is a problem with all typing I use wireless connection
You have a corrupted operating system - if you want to you can turnoff the mouse touch pad by the button just infront of the mouse pad but I've seen this before - all software related - you have major conflicts with device applications - do an F11 system recovery after backing up your data & don't forget your email adress.
Jul 07, 2010 | HP Pavilion dv6000z Notebook
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
Touch pad scrolling problem
I WAS READING AN ARTICALE IN THE TOUCH PAD SENTIVE ON THE MOUSE IS TO HIGH OR TO LOW
GO INTO CONTROL PANAL OPEN THE MOUSE LOOK IN THE PROPERTIES SETTING IN THE SCROL SECTION AND ADJUST THE SETTING WITCH WAY YOU WANT YOU WANT THE MOUSE TO WORK, WHEEL ADJUSTMENT MAY ALSO HELP ON HOW MANY LINE DO YOU WANT TO DO AT ONE TIME
Jan 03, 2009 | Acer Aspire 4520-5582 Notebook
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Ky pad not functiong lttr not typying
Please state what you are facing also tell us did you open it casing or any chances for the keypad filim cable detached
it can be due to the non connectivity or device driver issue, The best solution is to connect a PS2 or USB external key board and check its working or not then we can assume whether its a driver problem or a physical problem. New keyboard is also available you can replace it
Jul 04, 2008 | Toshiba Satellite M115-S3094 Notebook
Sony VAIO GR370 Notebook Logo
79 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
