Question about Philips Magnavox DVD/VCR Dual Player
When I preprogram the VCR it won't stop at the programmed time,it
Just keeps on recording. Thanks for any help you can give me. Mona
  • 360 Answers
When programing, ensure the stop time is being imputed for the same day and event as the start time
Posted on Jan 31, 2009
VCR stops recording by itself after a couple seconds.
Some VCR's will stop if the signal is not there. Retune the set if it uses Freeview. The broadcasters and those who are in charge of Transmitters like to mess around with the stations from time to time. This will effect the recording if you are using a model with the Guide Plus system. If you are timer recording it make certain that the settings are good. If it is an older model, make certain a thing called PDC is not on.
Dec 16, 2015 | Panasonic PV-7450 VCR
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
HOW TO PROGRAM MY VHS TO RECORD TV SHOWS TO SEE LATER?
Hi.
--make sure you have a blank tape in the VCR...
--GO TO MENU..
--your clock should show the real time..Correct it if it is not..
--select TIMER
--than select and adjust` start time` and `duration` of recording..and ` channel to be recorded `
--SAVE it..
--Turn off the video .
--you must see a small CLOCK/TIMER ICON on the LCD panel which proves that you did it..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 11, 2011 | Orion VR213 VHS VCR
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
I would like to tape my programs on the vcr(goldstar) I am not used to this product
do you wish to record while watching or while away.....while watching make sure your vcr is set to CH 3...when the show comes on press record
(a blank tape should be inserted) the red button on most vcrs.......while away the channel selector must be on the ch you wish to record...using the remote for the vcr press menu/program a event (this is where your vcr most have the correct date / time and not flashing 12:00)..set the day..time to start recording and time to stop recording..your ch will always be 3..now that vcr is set the main thing is make sure that cable channel selector is on that channel
happy recording
Aug 08, 2010 | Televison & Video
I MISPLACED MY USER MANUAL
You have to go the main menu and select record times, and day. Make sure you leave your tv set on, and on the channel that you wish to record the program on. You can set the start and stop times a few minutes before and after on the vcr, just to make sure you get the whole program. You can also set the vcr to record this program every day, any day of when ever you wish you can just manually hit "record on the vcr remote. Good luck, let me know how you make out! Thanks
Aug 12, 2009 | Televison & Video
I cannot set preprogramming on my vcr to the tv.
Have you set up the VCR on initial installation correctly!!
Remember correct date, day and time am/pm must be set firstly before any timed recordings can be done properly.
Jan 03, 2009 | LG MG64 VHS VCR
Hi this mona when I am chatting online I can hear the otherside, bhut its look like my mic is not working so other party didnt hear me.I would like to know if I go to cntrol pannel what shold I do? thanks...
Hi mona,
attach your mic and check and see if the sound recorder works if it does you should be in good shape
Start-> Programs->Accessories-> entertainment-> sound recorder
and check out if the wave file plays out sounds
if not tell me what mic ure using and what sofware came with mic
Cheers
Jul 04, 2008 | Audio Players & Recorders
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Philips Magnavox DVD/VCR Dual Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
