Question about HP PhotoSmart C4480 All-in-One Printer InkJet
Print is too cut off at top of page
Printer is not pulling the paper into the machine correctly.
    Genius:
  • 2,035 Answers
If the printer is pulling the paper properly then its the problem with rollers try these steps:
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 31, 2009
Why does my printer cut off top and bottom of page when printing, and sometimes side margins. But on the print preview page it shows it printing all of it.
Make sure you have selected the correct paper size to match the paper you are using. For example, your printer properties may be set to A4 (metric) while you are using Letter (8.5"x11"). These are slightly different in size and would produce the results you are describing.
Be sure to set your Default printer properties to the paper size you normally use so that you don't have to make the change every time you print.
Jul 26, 2014 | HP Officejet 7610 Wide Format e-All-in-One...
Tip
HP LaserJet LJ 4350 locks up when duplexing
Symptom: Your LaserJet 4350 prints just fine until you try to print a double-sided page. Then you see the page start to exit, pull back in, then stop. The Data light continues flashing green, and the display reads, "Processing..." There is no error indication, but the machine won't print the second side and continues to hold the half-printed paper in the duplexer. If you open the top cover and close it again, the printer will eject the page, then try to print the whole thing again, unless you're quick enough to cancel the job first.
Cause: The printer is expecting a different sized paper than what it's running. Often it's not the menu settings, but a little lever in the paper tray itself. Pull out the paper tray you're trying to print from and look for a little blue lever on top of its right-hand side. The lever is labeled "Standard/Custom." Flip it to Standard (parallel to the tray side) and your problem should go away.
on Mar 17, 2010 | HP LaserJet 4350dtn Printer
Paper alignment
You mite have a problem with paper setting or the draw settings. Could be that paper is set for metric size at the copier/printer and United States setting at the printer or vise a versa. Check to make sure that you setting are correct. DO the internal prints such as demo page and Network setting or counter page print OK if you have two draws print from different one or the bypass tray see if it changes?
Mar 06, 2014 | Konica Minolta magicolor 2500W Laser...
Printing pdf's, margins are wrong and cut off on top and left.
Hi
Choose the correct paper size of your printer for scanning and printer because I believe you select the incorrect paper size and it cut the pdf scanned file.
Go to printer icon, right click mouse and choose printing preferences and choose the correct paper size. Then go to scanning properties and choose the correct paper size.
Mar 16, 2011 | HP LaserJet 1022 Printer
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Paper doesn't feed correctly. Brother 2040
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
also if rollers are seen to be very clean and proper as new.then it can be paper pulling gears at the side of the rollers.if the gears are worn out from 1 side it will pull the paper but not in a proper way.in this case also rollers needs to be replaced,becasuse roller are not available in spare they come attached to the rollers.but a local printer repair shop can provide the only spare rollers as thay have it from old junk printers.
thanks.
Jul 13, 2009 | Brother Office Equipment & Supplies
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printing Alignment
Is the paper cassette set to the correct paper size and/or the printer driver printing to the correct paper size? Sometimes this can cause the image to be offset.
Sep 12, 2007 | Canon IMAGERUNNER 3530 Copier
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
202 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
