Question about Sapphire Technology (RS300-MA39) Motherboard
1 beep on a Sapphire PC- AM2RD580
After having problems with windows installing and not recognize the processor I tried to upgrade the BIOS did I kill the motherboard
  • Roberta Smith
    Roberta Smith May 11, 2010
    are you able to see the computer screen as it boots up ?
  • 530 Answers
Hi im josh in cebu phils. friend do not overclocked your pc. go to the bios again and select the restore default. snce that is on beep try check first the video card and the memory befre you restore the defaults. good luck
Posted on Feb 21, 2009
So I'm having a problem ... I bought a Pentium D 945, and after adding it to my system, I noticed that it gives me this : 1801-Microcode Update Error Missing or Invalid Processor Microcode Update. What...
Did you upgrade an existing home-built system, or it this a pre-built system from a PC manufacturer? Pre-built systems usually have processor-specific BIOSes in them that will only allow certain upgrades approved by the manufacturer. Home built systems where you purchase the mainboard yourself have a wider range of processor options written into the BIOS to allow for wider compatibility. The error message is saying that the BIOS does not recognize the CPU code from the specific processor you installed. It has nothing to do with the OS.
Nov 03, 2013 | Computers & Internet
Q9550 With Acer EQ35M MOBO
It is very likely that you simply do not have the right BIOS setup for the new processor. You will likely have to flash all your bios to get the new processor to both be recognized and to be able to recognize components on the motherboard. That is quite a jump in technology and it may be that the motherboard simply will not support the new processor period. In that case, be VERY careful buying your new board and make sure it specifically supports your processor. Sorry I could not be more help!
May 22, 2012 | Acer Veriton M661 PC Desktop
Bios Beep
Motherboard BIOS Recovery Jumper
  • Install the bootable BIOS upgrade disk which you previously created to do the original flash upgrade into drive A: and restart the system. If the update failed because you used the wrong BIOS update you should get the correct one and repeat this step. When the computer reboots there will most likely be no video prompts, however you can monitor this procedure using the floppy drive light and the PC speaker. When the PC speaker beeps and the floppy drive light is lit it means that it is currently copying the new BIOS onto the motherboard.
  • When the floppy drive light goes off and the PC speaker beeps (twice in most cases) the recovery should be complete. During the update procedure there might be pauses that looks like your computer is doing nothing, if so be sure to wait at least a minute to make sure the update is complete. When you are sure the BIOS update is complete and there is no more activity, power off the computer.
  • Change the jumper you changed before back into the original position so the computer can operate normally.
When you turn your computer back on your BIOS will be functional and you should be able to use your computer normally again.
Apr 30, 2012 | Acer VL460-UD4500C WINDOWS VISTA BUSINESS...
I have a acer aspire t660 pc. i buy a sapphire hd 5670 512mb videocard, but my pc dont reconise it. i test this videocard on another pc and it works. i try to change in bios the settings but nothing...
Make sure you set the primary graphics in the bios to pic-e and you will likely have to upgrade your power supply as this card requires at least a 400 watt you pc came with a 285 watt not near enough power for this video card and could be your problem
Feb 08, 2011 | Sapphire RADEON HD 5670, (512 MB) Video...
Upgrading from amd 3500+ cpu to 3800 duo
2 short beeps is memory parity error. Does the motheboard support dual core? Did you buy the correct socket type processor to match the mb?
Feb 19, 2010 | ASUS Computers & Internet
Bios verify error
Flashing BIOS from Windows can be problematic. It's usually best to boot from a removable disk and flash from DOS. You can make a bootable floppy using Windows XP if you have a floppy disk drive.
Also, your problem may not be a BIOS limitation, it may be a configuration setting in BIOS such as Clock Speed or a Multiplier. Double check those before trying to flash.
Jun 10, 2009 | Computers & Internet
Bios recognizes 4gig ram but XP OS only 3
You need a operating system 64buts to reconise the full 4 GB, there is no solution otherthen upgrade to XP 64 bit and you have to have a 64 bit processor as well good luck..
May 14, 2009 | Computers & Internet
Bios Failed During Bios Upgrade
pls check the RAM try re installing the RAM or try replacing them , may be it is a co incedent u thought it as a bios update failure pls check and reply back with mother board complete model number and manufacturer with processor details
and pls rate me if its helpful
Feb 24, 2009 | Gigabyte GA-K8NSC-939 Motherboard
Installing Pentium III processor on etower 433i
windows 2000 is good for pentium 4 not 3 you can not upgrade the prossesor without the mothboard and ram
Sep 28, 2008 | E-Machines etower 433i PC Desktop
Sapphire Technology (RS300-MA39) Motherboard Logo
75 people viewed this question
Top Sapphire Technology Computers & Internet Experts
David Payne
David Payne
Are you a Sapphire Technology Computer and Internet Expert? Answer questions, earn points and help others
