Panasonic CT-32SL13 32" TV
Problem for Panasonic CT-32SL13 32" TV
My Tau 32SL13 will not turn on at all. No video or sound.
By devinlindstr on Jan 31, 2009
I read some where that there is a fuse inside the TV that might need to be replace. Could that be true? Any info you might give me would be appreciated.
Best Solution
posted on Jun 18, 2009
Very Helpful)
jeffreyirish
Rank: Guide
Rating: 96%, 6 votes
You are likely correct that the fuse is blown.
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side bottom front, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic CT-32SL13 32" TV
Questions and Unsolved Problems for Panasonic CT-32SL13 32" TV
Do you recommend Panasonic CT-32SL13 32" TV?
Answer
Answer
Need A HDMI Cable From My PS3 to my TV and I don't find a HDMI port on my TV. any suggestions.
Answer
Panasonic CT32SL13G 2003 - problem - tv won't turn on
Answer
Well bought this TV; (Panasonic CT-32SL13 32") a while ago off of a friend, worked great up... (More)
Answer
How to change the fuse on a panasonic CT-32SL13G - FixYa
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , IL
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
