Question about Ryobi Backpack Blower 25.4cc
RYOBI BACKPACK BLOWER WON'T RUN PROPERLY
CAN GET IT TO RUN GREAT IF I TAKE THE AIR FILTER OFF AND PUT MY FINGER HALF WAY ON THE AIR INTAKE HOLE
SOURCE: The trigger on my ryobi backpack is not functioning properly.
You need to buy a new cable, clarified by Ryobi Tech Support.
Posted on Jan 23, 2009
  • 272 Answers
SOURCE: Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
Posted on May 12, 2009
bulldogchief
  • 388 Answers
SOURCE: how do you change the fuel filter on a ryobi
Disconnect the fuel Line from the carburetor and, using needle nose pliers, grab the fuel line in the tank just behind the filter and pull the line and filter out of the tank. BE CAREFUL YOU DO NOT PULL THE LINE ALL THE WAY OUT OF THE THE TANK!! Pull the filter off and replace with the new one and put the new filter back in the tank, then reconnect the other end of the fuel line to the carburetor. Hope this helps!
Posted on Sep 15, 2009
jdlipscomb41
  • 157 Answers
SOURCE: Low RPM's Ryobi 25.4 cc backpack blower
you need to adjust the carbarator
Posted on Sep 18, 2009
rwvanlue
  • 486 Answers
SOURCE: ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Ryobi b/p blower ry 08570 stalls out when givin the gas why and how can i correct this problem? do i need to throw it to the curb and buy an echo?
I would check your fuel filter and make sure you have all fresh gas in tank, then I would check to see if it will run with choke on , then I would check exhaust port and muffler screen for being plugged, then I would dissasemble and clean carb and check diaphrams and pump for being stretched and also clean out inlet screen and needle&seat . If all else fails I guess I would do the alternative either an echo or redmax or dalmar ! dalmar makes a great 4 cycle takes reg gas I have one it is great!!
Apr 15, 2011 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower Elbow
the home depot stores sell ryobi so i think they might have it if not they sure can get it for you, or you can always go to the ryobi website and try purchasing it that way.
Jan 23, 2010 | Ryobi Backpack Blower 25.4cc
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
Remove the muffler and you should find that it will run at full speed. The muffler is clogged with carbon. You will have to replace the muffler since it is sealed. If you want the muffler cleaned you can contact southern supply company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Sep 03, 2009 | Ryobi Backpack Blower 25.4cc
Backpack only runs low RPM, especially when cold.
Your carbeurator is gummed up. Remove the old fuel and make up a new fuel mix with new gas from the gas station. Then get a can of carbeurator cleaner spray. Three short squirts in the air intake and let it run. Three more squirts every minute or so until you dissolve the partial blockage that is causing your problem.
Jul 28, 2009 | Ryobi Backpack Blower 25.4cc
I pull the cord but it will not start, i have a Ryobi Backpack Bl
Ok that's half the battle. Probably the easiest thing to do is to clean the carb. So I would get some carb cleaner and using the little tube that comes with it spray into the high and low ports on the carb. Then spray in the outlet side of the carb.
Ps. Remove the little black and white caps and turn the screws on each while counting the number of turns to close (this way when you put the screws back in then all you have to do is count the turns to put them back at the factory settings). Now remove the screws and gently put the tube in each port and spray.
Also you may as well clean the filter with soap and water and let it dry. Once the filter dries take some fresh oil and drop a couple of drops on the filter and make sure it's has a small amount of oil in it.
Let me know how things go! Good luck!
Jul 15, 2009 | Ryobi Backpack Blower 25.4cc
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Jan 18, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi Backpack Blower 25.4cc Logo
789 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
