Question about Freezers
Making a high pitched solid beep tone
We have maintained according to instructions..any ideas??
  • 750 Answers
This is an alarm alerting you that the temperature has dropped or the alarm is bad and falsely alerting.
Posted on Jan 31, 2009
I have moved my freezer and now there seems to be a high pitch it was unplugged for a few days.
Just disturbing the chassis may have affected the unit being level, make sure with a level that it is ok.
Sep 09, 2016 | Freezers
NEW freezer making a singing/high pitched noise
That will be the expansion of the coolant turning back into gas and perfectly normal.
Nov 11, 2014 | Frigidaire Freezers
High pitch whistle after closing door
It is possible that the door gasket is defective
Jul 01, 2013 | Frigidaire FFU17M7HW 17 cu. ft. Manual...
Sears Kenmore Upright freezer is Making a loud humming sound
change the rubber washers on the compressor should work a treat...
Feb 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My freezer will make a very high pitched noise every once in a while. I have not been able to pinpoint a pattern at all.
Can you provide us more details about the brand of your freezer ,so that we can provide you correct diagnosis to your problem.
General troubleshooting will be due to fan blade which will be making high pitched noise .
Waiting for your reply .
Thanks for using Fixya.
Dec 08, 2009 | Freezers
3 beeps when in failure. makes ice for several hrs some times. compresser heat extreme. this unit is water cooled but h2o out put seams to low what should out put flow be?
First, 3 beeps means that the unit was in the freeze cycle too long and the 60 minutes back up timer kicked in and took over.
Now, for the water flow/ head pressure water cooled control.
You set the water flow for what ever it takes to achieve a head (High Side) pressure of 270 psi. the gallons per minute are of no matter. It's the pressure that you want to achieve and maintain.
If you fix the head pressure problem, the beeps should go away.
If you don't have a gage set, then measure the temp of the exiting water from the condenser. It should be in the 104 to 115 degree range. Any lower or higher, and the unit will not run like it was designed to do.
Hope this knocks it out for you.
Oct 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km-1300skf 3 beep error code
The 3 beeps indicates that the freeze cycle is longer than 60 minutes. with the suction pressure at 20, it sounds like low on charge (freon). I believe this is an R 404-A unit. Other things to look for are: Stuck float switch (in the up position), Water valve leaking, hot gas valve leaking, txv not feeding properly, weak compressor. Look at high side pressure too. It should not go below 210 psi during the freeze cycle. Low pressure should be in the middle to upper 40's psi.
Let me know if you need more.
Jan 02, 2009 | Freezers
Fridge freezer door alarm continuously beeping
make sure gasket is sealing also make sure light is going out.
Jul 17, 2008 | Freezers
Hoshizaki ice machine with constant beeping every 3 seconds
Most likely(50% of the times) Your Ice machine need a real cleaning. not just run clean cycle with ice machine cleaner. every 6 month call HVAC-R guys - machine will last half time longer if u schedule proper maintenance with them. I have seen It all: people try to call "friend", or someone who "knows" how this machines work. Real clean would take up to 3 hours for people who know what they doing. Here is one of my videos, when 3 beeps - long freeze cycle is not common and all others would offer You to get a new Ice Machine. Bill to the owner was 950$, New Machine 3450$ plus labour to install 600$.
Jun 23, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Compressor problem
The click your hearing is a thermal cutout that is kinda like a little breaker, it gets to the temp that it is designed for and trips. If its making a high pitch noise, more than likely the compressor itself has gone out and needs to be replaced, its getting a high load and triping the thermal cutout.
Sep 21, 2007 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
154 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
