SOURCE: how do I disconnect the clutch cable on my 2000 sportster.
relieve the pressure on it by loosening the nut below the handle on the cable, (use a back up wrench) that will allow the cable to be removed from the keeper on the engine side
SOURCE: Need to replace clutch cable on a 2002 H-D Dyna,
To replace the cable, you are going to have to remove the cover on the end of the right side of the transmission. Just follow the cable and see where it goes into transmission. You may have to remove exhaust pipes to do this. The threaded cable end screws into this cover. If the handlebars are the stock type bars, simply replace with a stock cable. If the bars have been changed, you'll have to match the overall cable length to get the right cable.
