Question about Dishwashers
I am trying to problem solve for dishwasher that is properly installed and is not working or even responding to being hooked up electrically. My husband tried to wire it and unfortunately wired it incorrectly the first time around (there were sparks and it blew the breaker.) We are thinking maybe it blew a fuse? Do they have fuses that can be replaced? I sure hope so! Help!!! -Alicia
  • clarkco2002 May 11, 2010
    what is the make and model of the DW
  • 318 Answers
No matter what brand it is the unit must have been hooked up power to ground to make a spark when turned on.
they dont have a fuse to protect them, but what may have happend is you could have shorted out a door switch.
be sure that you hae the wiring correct now and that your house fuse or breaker is on.
the wiring is very easy to hook up as black to black, white to white, and bare wire to ground.
i dont see how your husband could have done that wrong, but anything is possible.
recheck the power to the unit and just hope thats all thats wrong.
if you are sure power is good, then something in the unit has shorted out.
Posted on Jan 31, 2009
Connectingit hooking it up
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
2q== 9k=
Apr 10, 2014 | Dishwashers
Dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
My door was removed to be resprayed but the window and side mirror on the drivers side doesnt want to respond
Did the person who did the spraying hook the wires back in properly, or not even hook into auto? Ask them to look at it and make sure it was. If it was check fuses to mirror and door electrical output.
Feb 19, 2013 | 2011 Ford Fiesta
Our whirlpool dishwash is not cleaning the dishes very well so I pulled it out from the wall and un hooked the electrical and the water lines. After looking at it I hooked everything back together and I...
I've installed many DW's and haven't seen a reset on one. Take in mind, not saying that they're couldn't be one, but I doubt it IMHO. I've been installing all appliances proffessionally for 10 years and it just doesn't seem like there could be one.
Have you check your washing machine plug behind the machine to see if it's a GFCI plug? I've seen it happen where a consumer had done something electrical in the home and it tripped. They bought a new machine and we showed them that it was the outlet, they didn't even know that they had one behind the machine. I know this doesn't help much but good luck in the problem solving.
Dec 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not cleaning dishes properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
zzty
Jun 16, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
No electricity
I would check to ensure you have power to the dishwasher and that the door is closing/secure properly.
(i.e, Plugged-in properly under sink/back or washer, check for tripped circuit-breaker, and door latch is grabbing properly)
Jan 27, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Our dishwasher came without a manual . It runs FOREVER. Normal?
ok ...you have a wee bit of a problem...a new dishwasher even a floor model has a warranty..just call for service...best buy will send someone,,,now all units come with everthing accept electrical cord,,,i could only find drain hose part number 8269144,,but for owners manual go to servicematters.com..last just go back to best buy and find your model and see if you can get part number off installation kit..inside new unit.../
Jan 05, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Electicity going to dishwasher but when program dial turned it doesnt start program even though its switched on and door closed
small amount of water at bottom of dishwasher, electricity is going to the unit no breakers are blown, no light nothing responding on dishwasher
Sep 03, 2008 | Kenmore 16872 Built-in Dishwasher
How to install dishwasher your self
Is there an old dishwasher where you are installing the new one? It must be connected to a water line, a drain T and an electrical connection. If you have never installed a dishwasher before, it would be a better idea to have someone install it for you (preferrably a licensed installer) or you could have leaks or other problems down the line.
Feb 21, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
Top Dishwashers Experts
