Question about HP Pavilion dv6000z Notebook
Screen is dark (like there is no power on it)
Computer worked i powered down,when i went to use it again the screen was dark like there was no power to the screen.
the lap top is 14 months old and i am not happy about this.
  • 114 Answers
Well if you take a strong light like a flashlight and you can see a faint image. Then the lamp (CCFL) or the lamp's inverter has failed. It should work fine with an external monitor. Still not good though and usually expensive to repair (unless it is still under warranty).
Posted on Jan 31, 2009
Dropped phone now screen is dark
it had been a pcba hardware issue. the cpu of that pcba is damaged. if u give 214 degree heat and 117 power of air combined for around 2-3 min anti clockwise den it will work again.
Apr 01, 2014 | HTC EVO 4G Sprint - /
Screen goes dark after 5 minutes with sound
Could be the ballast boards for the white light.
Jan 04, 2014 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Olympus Stylus 1030 SW display not working after being in water
I just had a similar problem. I am not sure how it was fixed, but it works again - at least for now.
I had the camera on and was taking pictures when the screen went dark. Same as you describe, it takes pictures, flash works, LED, works, everything but the display. I plugged it into my computer with the USB adapter to see if I can salvage what is on the card and the diplay lights up. Tried several variations, but when the cable is connected to the computer (didn't have to be connected to the computer) the screen worked. Unplug, no display. I spun the settings button a couple of times. I accidentally took a couple of short videos and pictures that I deleted. I unplugged the camera and powered down again (tried that before). Power up and the screen is fine.
Again I have no idea what fixed it or why the display worked with the cable plugged in. It might have been related to the videos or some setting that I had slipped into (thought the display button never worked or changed anything).
Hopefully something in there helps or someone can explain what I did.
Oct 18, 2009 | Cameras
Screen went black
sounds like your monitor is shot or one of the connections in the back hope this helps regards Jim
Apr 20, 2009 | Computers & Internet
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Screen gone dark
It is natural to ipod the screen will be dark if has no power unless the LCD of your iPod is defected even it has a power its remain dark that’s the symptom of defected LCD screen. I hope your problem is a power failure only. Make sue your iPod is fully charged and then toggle the hold switch on and off. Then reset your iPod nano; Toggle the Hold switch on and off,(Slide it to Hold then it off again). Then press and Hold the Menu and Center (select0 buttons simultaneously until the apple logo appears ,about 6 to 10 seconds .You may need to repeat this step . If you having difficulty resetting your iPod set it on a flat surface .Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel,and not near the center. Then If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try your iPod nano with a different USB port on your computer, not a USB port on your keyboard or hub. iPod will stop charging if the computer, or portable computer, it's connected to enters standby, hibernation, or sleep mode. To charge your iPod, connect it directly to a computer's USB port and make sure standby, hibernation, or sleep mode is turned off. If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly. If you have an Apple iPod USB power adapter you'll be able to charge your iPod without leaving your computer powered on. If all procedure above for power to on is not working then its better to replaced the battery with anew one so its works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Apple iPod nano
Display Screen Went Dark...
This would seem like the power supply is broken and the computer is working off the battery or the setting need to be changed in power management. Whenever you disconnect the power supply and work form the battery, as power saving mode, windows will dim the back light to the display. First check if the power supply is charging the battery and then check your settings in the following: Start menu -  Programs - IBM - Battery MaxiMiser Wizard. Follow the steps until you get to the LDC display level. You may need to increase that.
Sep 09, 2008 | IBM ThinkPad T23 2647 Notebook
Acer aspire 3610 graphic or battery problem?
It sounds like your backlight is damaged. On some units this can be replaced on its own. On others, it requires the entire LCD to be replaced. I'll see if I can find out which this is, in your case, and find you a part number.
Sep 01, 2007 | Acer Aspire 3610 Notebook
HP Pavilion dv6000z Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
