Question about HP PSC 1610 All-In-One InkJet Printer
My HP 1610 sez color cartridge is wrong for this printer
I have had this printer for 3 years. Suddenly it gives me an error message that the color print cartridge is not right one for this machine! It's the #95 one, always worked before....how do I eliminate the error message without replacing the pricy cartridge?
  • Anonymous Jan 31, 2009
    My printer keeps telling me to check the color cartridge..Its a new one...fresh out of the package...they are not cheap either. What a piece of ****...I got it 3 years ago and it was working fine...then the darn thing is crapping out on me...guess its time to find a better model that isn't HP
    Genius:
  • 2,120 Answers
No way around the problem. Replace the cartridge.
Posted on Jan 31, 2009
Display says "Remove and check right cartridge", but even replacing the right cartridge with a new one does not fix the problem, and the printer will not function.
This HP PSC 1610 all in one - scan / fax / copier *** printer, normally the cartridges inserting
locations might have caused some issue. When you install the genuine catridge and getting the
error. Might be the catridge inserter might be replaced with local hardware engineer is the best solution. Moreover this type of printers are HP itlsef is giving the maximum life of 3 years only as printer life time.
In our office we are using HP PSC 1110 - 4-in-1 printer and it is having the same problem, but when the message displayed, we will just say OK and it will automatically print the necessary pages.
Best of Luck always.
Jul 16, 2009 | HP PSC 1610 All-In-One InkJet Printer
Can't clear ''remove and check color cartridge''
if you go on the hp website and click on live chat they will help you tho it
Nov 19, 2008 | HP PSC 1610 All-In-One InkJet Printer
Remove and checl color cartridge
The problem most likely is with the electrical contact between the color cartridge and print carriage. Even if you've replaced the cartridge, if the contacts on the carriage are still dirty, it won't make a good connection with the new cartridge and the error message will still appear.
Fortunately, the HP web site has a solution posted at the following link:
Cleaning Cartridge and Print Carriage Contacts
Good luck.
Sep 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP 1610 Won't Recognize the Color Cartridge?? Please Help!
i don't know who checks these messages, but I have the exact same problem, also with my mom's printer. it is no longer under warranty so HP wants to charge me thirty dollars for them to tell me how to fix it over the phone. no thanks.
Jun 04, 2008 | HP PSC 1610 All-In-One InkJet Printer
Remove and check color cartridge
I cleaned mine with alcohol and Q-tip and then shook it 25 times to insure that the ink was penetrating the application lines. My hunch is it first got dirty, and then dried up on the exterior prevent additional ink from leaving the cartridge.
May 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
Wrong Black Cartridge installed error message
Use original cartridges. Nowadays some companies resort to this cheap trick wherein if you put refilled cartridges, the printer wont work, giving errors and does allow you into head alignment tool..
Best bet is to use original inks.
May 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
try this. worked for me. when installing the cartridge, put one finger under the cartridge and hold upward pressure as you closed the green plastic cover. problem is the pins on the cartridge and the pins on the printer are not aligning properly by relying on the spring to do it. this will help to align the pins and should make it work.
Jan 10, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
237 people viewed this question
Ben Johnson
