Question about Electronics - Others
Replace lens I need to buy replacement lens for my dvd recorder toshiba DR-410 because it's damaged. Where can I buy it?
    Problem Solver:
  • 7 Answers
Tried lens cleaners? It could be most of your CD's are too scatched up & need to be cleaned or replaced! For maybe a replacement lens interenet sites for U.S. Toshiba DR-410 replacemnt lens parts?
Posted on Feb 04, 2009
I own a JVC DR-MV150B dvd recorder combo unit and have recently gotten an error of unknown disc when I put in a dvd - it ejects and gives this error over and over again - I have switch up many medias with...
Unfortunately the DVD laser may be faulty, in which case the whole DVD unit needs to be replaced. This is not likely to be economical and you are probably going to have to buy a new DVD recorder.
May 20, 2011 | JVC DR-MV150B DVD Recorder/VCR
DVD VIDEO RECORDER MODEL # DR -MV77SU / DR - MV78BU WILL NOT RECOGNIZE DISKS ,EITHER STORE BOUGHT MOVIES OR NEW DVD-R IMATION DISK RECORDED OR NEW. JVC TECHNICIAN RECOMENDED UNIT CLEANER .I HAVE BEEN...
yup you should try a disc cleaner to clean the lens of your device. it might be helpful to fix your problem. try to buy that on some eletronic store. hope that helps
CHARCOIS
Sep 16, 2008 | JVC Televison & Video
Cannot read disc
The reason your DVD player is not reading disc is because the lens is not reading the disc.
The reason the lens is not reading the disc is either because the lens is weak or dirty.
Try to clean the lens with a lens cleaner.
test it with a DVD, to see if it will work.
If it does not work, then the lens is weak and needs replacement.
to replace the lens,
open the player with the appropriate screwdriver, open the disc tray, and replace the lens with a new lens, test it with a DVD disc.
take care
Jun 15, 2010 | JVC DR-MH30S DVD Recorder
Does nothing when plugged in says it is loading and it doesn't
hello,
since your dvd keeps saying itis loading and it is not.
that simply means the lens of the dvd is already weak.
try cleaning it with a lens cleaner,
or better still you can replace the lens.
take care
May 27, 2010 | JVC DR-MX1S DVD Recorder/VCR
I need the unlocking code for toshiba dvd DR 410.
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to try here or here
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Aug 15, 2009 | Toshiba DR410 DVD Recorder
Dvd stopped playing saying disc error
this means it cannot read the disc,try a lens cleaner it will work,if it doesnt replace the dvd lens.
Jul 25, 2009 | JVC DR-MV5S DVD Recorder/VCR
My jvc dvd recorder will not read any dvds is
First off I would try to buy a NEW DVD Lens Cleaner and give a Good few Cleanings. As far as to fix it, If cleaning doesn't work it is better to check out recent models and replace it. Newer models also have Up-Scalers which convert the signal to a higher quality to perform better with HDTV's. This will probably cost only $100 more than a Repair. Be careful with ALL of the discs that you put in are CLEAN, That is what causes ALL the Damage to Disc based Machines! Good Luck
Apr 29, 2009 | JVC DR-MV1S DVD Recorder/VCR
Dvd burner malfunction
Have you tried a lens-cleaning disk? Data on DVDs is much more closely packed and so the weaker signal prehaps more likely to be lost to a dusty lens.
Oct 06, 2008 | LG DR-4810 DVD Recorder
LG DR 165 DVD Recorder problem
hi , how are u friend
i have problem pls can y help me
lg dr4810 afiche in lcd (please wiat )
Sep 28, 2008 | LG DR-4810 DVD Recorder
DVD Recorder/VCR combo shuts down during DVD recording
If the device is still under warranty then it is worth calling and getting a repair/replacement. If not, then go with the new unit. it sounds like the one you have was not a very good unit to begin with. make sure you read the consumer reports on new available units before buying, so as to avoid buying another lemon.
Feb 02, 2007 | JVC (DMRV1S) Burner
Electronics - Others Logo
67 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
