Question about Philips GOGEAR SA6045 MP3 Player
Philips gogear all it does is load then black out
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Feb 07, 2009
My philips gogear mp3 vibe sends the message "must
First of all have you loaded the gogear from the philips media converter and is the whole space filled up. In some cases there must be a space on the memory as the system may work very slow if the memory is full. Try and delete some files in this case. Also load only safe files that are scanned and has no malwares.
Hope you try this out.
Oct 19, 2011 | Philips GOGEAR SA6045 MP3 Player
How do you load movies on to the philips gogear aria?
Almost same as with the any sanza mp3 player
but instead of Sanza Media Converter you need Media Converter for Philips
1) download "Media Converter for Philips"
2) install the download
3) sync your Philips gogear with your computer
4) load "Media Converter for Philips"
5) Drag videos to the converter
6) click convert
the videos will automatically be transferred to your gogear in from there
Jan 05, 2010 | Philips GoGear SA3125/37 MP3 Player
I turn on my Philips MP3 player GoGear goes and turns itself off!
Install philips device manager that comes in the cd alongwith the player and then use the repair tab to repair the device
Aug 27, 2009 | Philips GoGear Flash MP3 Player
I turn on my Philips MP3 player GoGear and it goes off!
are yaar.....there is a hold or keylock button just unlock that....
Aug 27, 2009 | Philips GoGear SA178 MP3 Player
Philips gogear mp3 8gb
Make sure the hold/lock is not engaged first.
Run a Repair using the updated version of the Philips Device Manager on Philips website - www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 31, 2009 | Philips GoGear SA5285/37 Digital Media...
Cant load Phillips gogear software
I would check Start --> Philips Digital Audio Player --> Philips Device Manager
If it is not there, check to see if the laptop is running Vista. If it is a Vista OS, get the firmware upgrade and updated software directly from Philips website
Nov 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips gogear 8gb sa6185 synch
Do not see the drive for the SA6185 after installing software from CD.
May 11, 2008 | Philips GoGear Flash MP3 Player
Philips gogear
Windows XP has a native driver that will work - if your computer is not recognizing the device, then unplug the GoGear from computer, turn your GoGear off, and hold in the volume+ button. Reconnect the GoGear to your computer while still holding the volume+ button. After 5-50 seconds, Windows should say Found Hardware Wizard and will load/reload the needed drivers.
Otherwise, you may have to reinstall the installation CD (does not work with Vista) - it has a key component called Philips Device Plug-In which needs to be reloaded.
Mar 26, 2008 | Philips GoGear HDD6330 MP3 Player
Wont load on computer!!! "Unrecognizable"
Back up your files on the device, if possible and then perform a Repair:
Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
You will now be able to load the firmware upgrade that makes it compatible with Vista.
open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the Update tab.
Also, it sounds like your new laptop has the Automatic synchronization option selected for Windows Media Player. To fix this:
1) Backup all files stored on your GoGear, as this process will delete all files from your GoGear
2) Go into Windows Media Player 11 with your GoGear connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portbale media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding songs/files you don't want into your player.
-Tha Mp3 Doctor
Jan 09, 2008 | Philips GOGEAR SA6045 MP3 Player
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 20, 2007 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
