Question about TruTech PLV1615T 15 in. LCD Television
Trutech tv will not play dvd's anymore
When we try to put a dvd in and it starts to read it, we get a message that says wrong disc. How do we correct this?
Have you tried a lens cleaner. They are about $5 . Use like a normal cd/dvd. This is the most likely cause that wont require dismantling
Posted on Aug 01, 2007
3 Suggested Answers
SOURCE: READS WRONG DISC
Lg tv no sound
Posted on May 11, 2008
  • 814 Answers
SOURCE: TV won't playback DVD-RW Disc recorded on another TV.
You can try calling TruTech customer service for technical assistance at these telephone numbers. 1-888-252-6252 and 1-800-252-6123. They should be able to answer all your questions about the type of DVD's you can use with your television. I hope this helps you with your problem.
Posted on May 17, 2009
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Liteon dvd recorder lvw1101 starts reading the dvd then says it preparing the disc then it ejects it
The Optical head unit is faulty. The disc is not being read by the head unit laser and so conveys a wrong message which ejects the cd.
Replace the optical head unit assembly but with the correct procedure.
Sep 11, 2010 | Lite On LVW-5045 DVD Recorder
I get a "wrong Disc"message when i put in a dvd
This generaly means the laser is having a tough time reading the disc. You can try cleaning the laser lens.
Apr 24, 2010 | Dynex DX-PD510
I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
Mar 07, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 18, 2010 | Microsoft Xbox 360 Console
Dvd won't play disc
hi. the actual lens assembly has become unstable and this is misaligned the lens. it is unable to line up correctly with the inserted disk so that it may recognize and read the data. when this occurs, the default reading will be WRONG DISK.
You with have to replace the entire lens assembly, which is one whole piece, to actually restore this unit to its original state.
Please rate and god less:)
May 13, 2009 | RCA Televison & Video
DVD not reading but spinning
Are you using +R discs(not the -R)? Use Sony brand +R or try using a few +RW's and see if that corrects the problem.
Feb 23, 2008 | iLO DVD Recorder DVDR05
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Sampo
POWER ON
OPEN/CLOSE
Key in 3,3,0,8,8,0 on the remote for region-free
OPEN/CLOSE
POWER OFF
Oct 02, 2007 | Sampo DVE-612 DVD Player
TruTech PLV1615T 15 in. LCD Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
