Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water is collecting on shelves and bottom of refrigerator.
  • bzz234 Jan 31, 2009
    Freezer and refrigerator are cold and seem to be working OK. Just have water collecting on shelves.
  • Anonymous Feb 21, 2009
    I have water leaking from filter compartment onto the shelves. What is the best way to alleviate this problem? The fridge and freezer and icemaker/water dispenser work great!
  • 360 Answers
This is most likely condensation from moist air entering the refrigerator. If the door is not opened often, you may need to check the door seal to ensure it is intact and sealing properly.
Please take the time to rate this solution
Posted on Jan 31, 2009
Water is collecting at the bottom of the refrigerator under the drawers
You may have a bad gasket, which is allowing moisture laden air to be sucked into the refrigerator. The moisture then condenses on the walls / shelving, and finds its way to the bottom.
Feb 13, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water is collecting on the shelves in the main compartment
Sounds like a typical defrost drain blockage. Not sure what model of profile you have if older or newer stile but when the defrost cannot drain to the pan below the refrigerator the water collects inside th refrigerator creating a mess. I'm going to send you to another web page that will help you see a better idea of just what i'm saying so we can help you resolve the problem and learn how to clear the drain and get the water to stop messing up everything. Be right back putting our daughter to bed and brushing her teeth, Sea Breeze
Mar 01, 2010 | Refrigerators
Water is collecting in veggie bins in
I can solve your problem for you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 11, 2009 | Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Water collecting on the shelves
Sure are a lot of sweaty fridges out there. My wife complains about it too. A mis-fitting door will allow moist air inside. Brute force usually fixes that. I just put my foot against the door bottom and bend the door back to where it belongs. If it has drooped, try just forcing it back up. And don't keep the door open too long when looking for stuff.
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water of unknown source is on shelves of refrigerator
could it be from the ice maker or the water in the door.
Mar 24, 2009 | Kenmore Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
98 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
