Sounds like you have wireless Controllers. Be sure your batteries are good on the Controller and the controller is turned on, LED should light. Plug the receiver into the controller jack, and it should light up at least one LED. If you have channel number selector, set it to the same number on the controllers, channel selector.
If old wired controllers will work, then you have dud wireless controllers. I know that cheap poor quality wireless controllers exist out there. You may have a dud. I also know that sometimessomething kills the controller ports on the PS2. The only way to know is to hook a wired controller you know works into the port to see if the port is good or bad.
I just bought Guitar Hero 5 and it won't play. Megatrom games said I need to get my machine serviced...
(More)
I just bought Guitar Hero 5 and it won't play. Megatrom games said I need to get my machine serviced as it will not accept dual layered discs like Guitar Hero 5. Where do I get it serviced? I live in Benoni, Gauteng, South Africa Ursula
My PS2 starts scratching disk in lined circular motion.I suspect the Lazer Ribbon Cable's work since...
(More)
My PS2 starts scratching disk in lined circular motion.I suspect the Lazer Ribbon Cable's work since I found dust of CD on it. What should I do?
konsole schaltet beim spielen ab.eine zeitlang kann ich spielen ohne probleme dann...
(More)
konsole schaltet beim spielen ab.eine zeitlang kann ich spielen ohne probleme dann urplötzlich ist das gerät aus. bei menuewechsel kommt es auch öfters vor.
