Question about Kenmore 24032\24036 Top Load Washer
I took the transmission out and it won't go allthe way back in.
It acts like the the clutch is sitting too high. I need an exploded view of the inside of the transmission.
  • 5,911 Answers
For an exploded view of the inside of the WASHER, go to either searspartsdirect.com or appliancepartspros.com. Just type in your COMPLETE model number and both sites will have what you're looking for. I do not know any where that would have an exploded view of the inside of the transmission, as these units are not normally repaired by the consumer. They are replaced as a whole assembly. If you have questions, please let me know. I hope this helps you.
Posted on Jan 31, 2009
  • Jeff Rockwell
    Jeff Rockwell Jan 31, 2009
    "Thanks for Trying?" All you requested was WHERE you could find exploded view drawings of your washing machine. You did not include a model number so I could verify the information, nor did you follow up with comments about whether or not it was a simple matter of needing to view the washer interior, or the internal components of the transmission. The two websites I referenced are notorious for having helpful illustrations with extensive parts listings. I further explained to you that these transmissions are normally NOT repairable at the consumer level. If they are non-functioning, they are normally sold and replaced as an entire assembly. Since I was certified to work on these model washers, I know this, because I used to have to order the parts for them. Did you view the websites that I had mentioned? If so, did you find what you were looking for? If not, did you need further assistance? Did you have questions? The last sentence I wrote to you, requested that "if you have questions, to please let me know". Communication from the consumer is essential to be able to come to a viable solution to correct your problem. Feedback, rather than adverse ratings with no comments, would have been a more constructive way of trying to resolve your problem.
Trouble shoot 2500masda truck that won t start after I replace clutch and slave cylinder
Did you reconnect the wires and re-position the clutch safety switch at the clutch pedal assembly? If this switch is not positioned or connected correctly it will not allow the truck to start.
Feb 25, 2015 | 1999 Mazda Pickup
Clutch slipping in and out in second gear only. What do I need to do to fix it.
Hi Stacy, and the usual suspects are:
1. Clutch controls improperly adjusted.
2. Insufficient clutch spring tension.
3. Worn friction discs.
For more information about your question please visit the website below. Good luck and have nice day
.Delboy Garage Harley Sportster Clutch Adjustment
May 08, 2012 | 1979 Harley Davidson XLH 1000 Sportster
Low power
if it revs a lot but doesn't actually speed up, that means the clutch is slipping. This can occur if transmission oil is LOW but also the clutch plate is a wearable item and does need replacing once worn out. Your actual transmission should be ok if this is all the problem is. The clutch is essentially what transfers the power from the engine to the transmission, through the use of the clutch pedal. the clutch is made up of a clutch disc, and a pressure plate, and a pilot bearing, more or less.
The clutch disc acts sort of like a brake pad, and sits in between the pressure plate and the flywheel. When you let off of the clutch pedal, the pressure plate contacts the clutch disc, and pushes it against the flywheel, locking the transmission and motor together, thus transferring engine power to the transmission.
When the clutch wears out, the clutch disc no longer has enough friction material to effectively 'lock' both together, and the full power can no longer be transferred, which is when the transmission slips. Eventually the car won't move if it isn't replaced.
In my opinion it'd be in your best interest to take it to your local dealer and have them check it out.
This is a common issue with any transmission of a car, and it is a fairly straightforward fix, however it may be somewhat pricey as it is a labor intensive job.
Dec 08, 2011 | Cars & Trucks
Can you explain to me how to change a clutch on a 2007 honda crf250r,my son took it apart and has questions about putting it back together
Go to the website below and you can see an exploded view of the clutch assembly. Do the "Parts search by model". If that doesn't answer what you need, reply with specific questions and I will try to help further. Please rate my answer. Thanks. www.babbittsonline.com
Apr 23, 2011 | Honda CRF 250 R Motorcycles
Clutch just quit engaging, found small spring in the case/cover, need an exploded view of clutch assembly and a photo of new clutch plates.
For an exploded view of your clutch, go to www.bikebandit.com . The only spring that I can think of in the area is a small srping in the release mechanism but I can't figure how it got inside the case. As for your clutch plates, as long as they've got the oil grooves in them, they're fine. Although they don't look like much, they'll work.
Good Luck
Steve
Dec 25, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Ok so ive changed the oil im about to get inside and hopefully unstick the clutches any advice on were to get a diagram or any advice ive never done this so im trying to be very carefull also will deep...
Got to BikeBandit.com. Click OEM parts and look up your bike. They've got great exploded views of every part of the bike. I wouldn't use the penetrating oil. Now, what you might can do is put the transmission in top gear, hold the clutch lever in, and rock the bike back and forth. Sometimes that will break the clutch loose but it can also tear the friction material off the metal backing disc. The best thing is take the clutch apart.
When you get the clutch plates out, wash them in gasoline. Do not smoke while doing this and be very careful of static electricity. Gasoline is the only thing I've found that would break the glaze otherwise I'd say use something else, Just be careful when using it. Once you washed all the plates off, lay a piece of medium grit emory cloth on a flat surface. Lay the friction plates on the emory cloth and lightly sand them using a figure "8" pattern. Just lightly. Put the clutch back together by installing a friction disc, a metal disc, a friction disc, and so on.
You'll do fine. Just remember, don't force anything. If something is supposed to come off but doesn't seem to want to, look for another bolt that you may have overlooked.
Good Luck
Steve
Sep 29, 2010 | 2002 Yamaha TT-R 125
HOW TO open a getrag f23 transmission? I've got my f23 (m86 cobalt transmission out i have broken syncros) and i am trying to take the tranny itself a part i took all the bolts on the clutch housing and...
Look inside the bell. There should be a plate there. remove the plate and you will find a bolt under there. If you are not a regular trans person, I don't recommend fixing this yourself. That trans needs a special fixture that it sits on to take apart and put back together.
Standard transmissions are not that expensive when you get one from a wreck. (At least not here in upstate NY), If you make one mistake you will be pulling it back out, Even owning a trans shop for 25 years and rebuilding everything from Merc. to chevy's I rarely made any money rebuilding a standard and always recommend used except when there was a design flaw like the Ford exploders of the 90's when my repair fixed the flaw.
Good luck and hope it works for you.
Nov 06, 2009 | 2007 Chevrolet Cobalt Coupe
700R4 transmission diagrams needed
Im needing and exploded view of the inside of a 700 R 4 transmission
Jul 31, 2009 | 1992 Chevrolet G20
Truck wont go
Have you checked the output and dog gears in the transmission? I broke the teeth off my forward gear and all it was doing was revving up really high but not going anywhere, it would still go in reverse though. Traxxas.com has exploded views of the transmission so you can take it apart and look inside to see if there's any gears missing teeth, or if any of the bearings are seized.
Feb 24, 2009 | Traxxas Rc Revo Nitro Monster Truck
Kenmore 24032\24036 Top Load Washer Logo
183 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
