Question about HP OfficeJet 7110 All-In-One Thermal Printer
Hp 7110 printer problem
My printer says it is ouy of colored ink, but it is a new, I have cleaned the contacts, did the semi restart thing but still says out of colored ink, whats up
    Genius:
  • 2,120 Answers
I have seen many new defective ink carts. Replace it.
Posted on Jan 31, 2009
Cartridge error appearing
please mention, what error.
clean the ink cartridge (the golden contacts) and also the inside of the printer. after cleaning the ink cartridge, do a semi full reset.( unplug the power , and then press and hold # and number 6 button together, and while holding them down plug in the printer again.. you will have to continue holding the buttons down for some time until the display says semi/nvram reset).. nOw release the button.
then turn the printer on , and after that insert the ink cartridges
Aug 12, 2010 | HP Officejet 4355 All-In-One InkJet...
My printer says ink cartridge error . I cleaned the area where the ink goes in and purchased new cartridges but it still tells me somethings wrong. Any Ideas ?
1. Go through the below web link to resolve ink system failure
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=311255
if the issue still persists, perform partial and semi full reset
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
Sep 12, 2009 | HP Officejet 5510 All-In-One Thermal...
Epson Stylus CX 4200 won't print color copies of anything
Uninstall the printer software.
Restart your computer.
Download the latest drivers and software for the printer.
Load the software.
Part of the software could have corrupted itself...
Jun 11, 2009 | Epson Stylus CX4200 All-In-One InkJet...
All color indicator lights and ink cartridge light lit
Hello Miriam703,
I had the same problem, all cartridges lights came on.
I did two things:
1st: I clean the print cartridges plugs with Q-tips, just to insure there wasn't any ink build on the plugs. If you look were the cartridges are, you will see four plugs one for each of the cartridges. Each plug has four contacts. They should be a bright metal color. If they dull in color, they have ink on them. Unplug the printer and pull all the cartridges out and gentlely wipe the the contacts with Q-tips. Re-stall all the cartridges.
Note: The cleaning did not solve my problem but its good maintenance since in was looking for a solution.
2nd: What work for me was I un-stall my printer totally. Turn off the printer then turn off the computer, had a cup of tea, rebooted the computer and re-install the HP cd disk and drivers, turn the printer back on. After I reinstall the software and put the printer back on my network, everything is working fine for the last two days. The lites are off and the HP toolbox is reading the ink cartridges status correctly. I believe that a virus change the printer drives.
Solution by;
eagleeye140
Jan 30, 2009 | HP Officejet Pro K850 InkJet Printer
Kodak EasyShare 5100 won't print
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Sep 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Hp 6110 printer
The issue that you are experiencing might be due to various reasons.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
Please check the same and try the below given instructions to get the issue resolved.
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings :
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Wish you good luck!
Regards,
Lawrence
Mar 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Photo printing
this might be due to the ink. Try to clean the cartridges and check for the color copy from the front panel of the printer. If the issue is same, try with the power cycle and semi-full steps as follows
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Semi-full steps:
Jan 13, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Colored Ink problem
Make sure you are using the correct cartridges for the Z35. They should be #26 (color) and #16 (black).
Make sure the contacts are clean where the cartridge connects to the printer electrically. A little alcohol wipe is good for this. Clean contacts on both the cartridge and the carrier in the printer.
Nov 19, 2007 | Lexmark Color Z35 InkJet
HP OfficeJet 7110 All-In-One Thermal Printer Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
