Question about Bissell 8806 Powersteamer Upright Vacuum
8806-m power steamer power lifter will not disperse solution
I used this bought 1/8/09 carpet cleaner once and now it will not
put the solution onto the carpet and there are no repair places doing
warrenty within a reasonable distance
  • 360 Answers
These are really great units, chances are the tank isn't seated properly or the pump has lost it's prime. Check the owners manual for troubleshooting. I have included a link to download the owners manual if you are unable to find yours. Click here to download
Hope this helps.
Please take the time to rate this solution
Posted on Jan 31, 2009
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
Why won't my Kirby carpet cleaner disperse
check all conections are on tight and no brakes in them this link may help you
http://www.goodvac.com/Articles.asp?ID=153
May 08, 2013 | Vacuums
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
I have a Bissell Power Lifter Shampoo Machine but no instructions
I have a bissell power lifter shampoo machine and no instructions.
Oct 01, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Bissell carpet cleaner does not have suction like it should
Try checking the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic filter with a door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and you should have full suction once again.
Mar 16, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Instructions or manuel was not included.
i downloaded the manual for your machine, but not sure how to access it for you,but i do know about the problem, the tank that sits down on the front of the steamer and it has 2 clips that you push in to lock the tank is where your dirty water is put in when you are cleaning your carpets. the tank above ,the one where you put your solution and water in is what is used to shampoo your carpet. on the handle is a trigger (black) button ,this is the button you push in to release your solution onto your carpet. release the button to extract the water from your carpet,moving your steamer in a back and forth motion. the trigger button is the only button on the machine and is only used to put the water /cleaner located in the upper tank on your carpet, releasing this button and moving your steamer back and forth over the shampooed part with extract your dirty water into the tank that sits below the solution tank. go on www.hoover.com and click on carpet cleaners ,scroll down to find yours and click on manual. and the owner manual will download and you can print it out for future reference, i hope this will solve your problem, sandy
Nov 29, 2008 | Hoover F5810 SteamVac Upright Vacuum
Bissell carpet cleaner not spraying water out of bladder
my bissell machine was bought 2nd hand and I can see where to put the water in...too complicated...anyone have the bissell proheat pro-tech with scotchgard i believe the model # is 010-5458
May 08, 2008 | Vacuums
Bissell 1697W power steamer
I JUST PURCHASED A NEW BISSELL CARPET CLEANER AND THERES NO INSTRUCTIONS IN MY BOOK AS TO HOW MUCH CLEANER TO USE, IT SAYS ON THE BOTTLE OF CLEANER THAT CAME WITH IT,IT SAYS TO ADD 5OZ.OF CLEANER TO EACH GALLON OF HOT TAP WATER
Apr 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bought it used with no manual
Bissel has a manuel go to this link:http://www.bissell.com/images/UserGuides/8806_1008.pdf
Jul 23, 2007 | Bissell 8806 Powersteamer Upright Vacuum
Bissell 8806 Powersteamer Upright Vacuum Logo
351 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
