Convertions how many liters are there in 3 pint and 4 quarts?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
Three pints is 1.419529419 liters.
Four quarts is 3.785411784 liters.
Posted on Jan 17, 2010
How many pints are in 3 gallons
2 pints to a quart , 4 quarts to a gallon, 8 pints to a gallon logically 3 gallons would equal 24 pints (3X8=24)
Jan 31, 2018 | Garden
Need recommended Fluid specs and amounts to change oil for 1996 Toyota Tacoma 4 wheel drive front and rear axles
Hello there,
From this page https://www.worldsbestoil.ca/product-cross-reference.php?year=1996&make=TOYOTA&model=TACOMA&engine=2.7L&vin=1
Extract.......
.Engine, 2WD, with filter - 5.4 quarts [1]
Engine, 4WD, with filter - 5.3 quarts [1]
Cooling System, Initial Fill - 9 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A340E Initial Fill - 1.7 quarts
Automatic Transmission, A340F Initial Fill - 2.2 quarts
Automatic Transmission, A43D Initial Fill - 2.6 quarts
Automatic Transmission, Total Fill
4 speed A340F - 10.4 quarts
4 speed A340E - 7.7 quarts
4 speed A43D - 6.9 quarts
Manual Transmission, - 5.3 pints
Differential, With ADRD Front - 2.6 pints
Differential, Without ADRD Front - 2.4 pints
Differential, 2WD Without LSD Rear - 6 pints
Differential, 4WD Extra Long Rear - 4.5 pints
Differential, With LSD Rear - 6.4 pints
Differential, Standard Rear - 6 pints
Transfer Case, - 2.2 pints\'
Sep 13, 2014 | 1996 Toyota Tacoma
How many cups are in a quart
2 cups make a pint. 2 pints make a quart. A quart is almost a liter.
Sep 02, 2014 | Cooking
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
How much transmission fluid is need for a 1990 dodge d150
4 sp. 7 pints.
5 sp. 4 pints.
auto. 17.1 pints except A 727 trans with lockup 16.7 pints.
Feb 22, 2011 | 1990 Dodge D150
What type of Dana is in the rear of the 98 4cyl wrangler
Engine, with filter..........6.1 quarts [1]
Cooling System, Initial Fill..........10.6 quarts
Automatic Transmission, 30RH Initial Fill..........4.1 quarts
Automatic Transmission, 32RH Initial Fill..........4.1 quarts
3 speed 30RH..........7 quarts
3 speed 32RH..........8.6 quarts
Manual Transmission, AX-5 2WD..........7.4 pints
Manual Transmission, AX-15 2WD..........6.8 pints
Manual Transmission, AX-15 4WD..........6.8 pints
Differential, 181 FBI Front..........2.6 pints [2]
Differential, With 194 RBI Rear..........3.6 pints
Differential, With 216 RBI Rear..........4.1 pints
Transfer Case, 242..........3 pints
Transfer Case, 247..........3.4 pints
Transfer Case, 249..........3.4 pints
Transfer Case, 231..........2.2 pints
Feb 14, 2011 | 1998 Jeep Wrangler
1995 Chevy Astro Van transmission fluid level? How many quarts should be in there with a 4.3 engine?
From a totally dry condition with Torque Converter empty the book indicates 4 Quarts. The best way to check is to add 1 pint if you are at the low marks with the engine warm and idling in Park. If you have drained the Transmission to change the filter, start by adding a quart and then check level and add a pint then check level, continue the process of adding fluid a pint at a time and checking level until you get the level to a place between the marks. Drive the vehicle for a few blocks, check and add fluid as needed.
Oct 17, 2010 | Chevrolet Astro Cars & Trucks
How many quarts of transmission fluid goes in a 2000 ford explorer /
Hello there
abar_a.gif?v=72006
2000 FORD TRUCKS EXPLORER 5.0L 8-cyl Engine Code P
FILTERS
AMSOIL Ea Oil Filter.........EAO11
Wix Oil Filter.........51372
AMSOIL Ea Air Filter.........EAA122
Wix Air Filter.........46253
Wix Fuel Filter.......33595
Wix Trans Filter.....58955 [1]
[1] 4R70W
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........15.0 quarts
Automatic Transmission, Others Initial Fill..........3.9 quarts[2]
Automatic Transmission, 4R70W Initial Fill..........5.0 quarts[2]
4R70W..........14.0 quarts
2wd ..........10.0 quarts
4wd ..........10.0 quarts
Manual Transmission, ..........5.5 pints
Differential, Rear..........5.7 pints[3]
Differential, Dana 35 Front..........3.6 pints[4]
Transfer Case,Full-Time 4WD..........2.7 pints
1. When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase.
2. With ENG at operating temperature, shift through all gears. Check fluid level in PARK and add fluid as needed.
3. Fill to no more than 1/4 to 9/16" below fill plug hole.
4. Fill no higher than 9.5 mm or 3/8" below fill plug.
Aug 07, 2010 | 2006 Ford Explorer
What kind of ATF goes in my 1992 cherokee?
Use ATF+4
Do not use Dexron or Mercon
Aug 08, 2009 | 1992 Jeep Cherokee Sport
What;s the oil capacity for a 2002 chevy trailblazer 4.2 6 cyl?
Here are the Fluid CAPACITIES & MORE:
Engine, with filter..........4.6 quarts[1]
Cooling System, Initial Fill..........12.0 quarts
4 speed 4L60, 60E..........11.0 quarts
Manual Transmission, NV1500..........5.7 pints
Manual Transmission, NV3500..........4.2 pints
Differential, with 8.6 ring gear Rear..........4.0 pints
Differential, with 7.25 ring gear Front..........2.5 pints[2]
Differential, with 8.25 ring gear Front..........4.2 pints[2]
Differential, with 9.25 ring gear Front..........5.9 pints[2]
Differential, Rear..........4.0 pints
Transfer Case,BW4472..........2.5 pints
Transfer Case,NV136/236/246..........4.0 pints
Transfer Case,NP207..........4.6 pints
Transfer Case,NP231, NP233..........2.3 pints[3]
Transfer Case,NV231/233..........2.1 pints[3]
1. After refill check oil level.
2. Do not use synthetic lubricant in axles using RTV sealant.
Synthetic lubricant will chemically atack RTV sealant.
3. Identification: check tag on case.
Apr 13, 2009 | 2002 Chevrolet TrailBlazer
80 people viewed this question
k24674
jasbo
jasbo
